th350 stall not working
Old May 16, 2006 | 09:53 PM
zdrag28's Avatar
Car: 85 z28
Engine: 327
Transmission: th350
Axle/Gears: ford 9in 4:56 to 1
what would cause the trans to be locking up when put in gear?
has a 3800-4200 stall converter from tsi in a 350 turbo but it is locking up as soon as it is put in gear trans was built by jackson performance and everything is new
Old May 17, 2006 | 03:35 AM
ede's Avatar
ede
think i'd call the builder and elt them figure it out if it's all new. my guess would be a valve getting stuck or not working.
Old May 17, 2006 | 11:46 AM
Shagwell's Avatar
Car: projects.......
as in it locks-up and stalls the motor out, or as in the car still learches forward going into gear?
Old May 17, 2006 | 01:39 PM
snm92rs's Avatar
Car: 1992 RS
Engine: 5.0 LO3
Transmission: A whacky A4
I had that problem on a 700r4. I put the TCC valve in upside down. I also had the wrong separator plate gaskets in there. Since I think you are using ath350 then this may not be of any help. Also if the stator one way clutch is not holding in the converter the your stall speed will be lower and you will have almost no torque multiplication. Just some thingds to keep in mind.
Old May 18, 2006 | 10:55 AM
zdrag28's Avatar
Car: 85 z28
Engine: 327
Transmission: th350
yes it locks up and wants to stall out the motor if I hold the throttle a little it wont stall but does push the car
also has very little to, no line pressure
Old May 18, 2006 | 12:05 PM
Shagwell's Avatar
- you've got problems. If you have little line pressure, I'd lean more towards the trans than the converter. If the motor is running, the pump is turning.
Old May 18, 2006 | 07:17 PM
zdrag28's Avatar
Car: 85 z28
Engine: 327
Transmission: th350
what should I check or look at? I pulled the lines off and started it some fluid came out(barely any) but it was not coming out with any force
the tranny was built in missouri by a company called jackson performance shipping will be expensive and TIME, consuming Any thoughts on what I should check out?
Old May 19, 2006 | 12:13 PM
Shagwell's Avatar
I'd start by calling jackson performance and telling them you have little to no line pressure and see what they say.
Frozer!!!
Jan 19, 2024 04:55 PM
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
TreDeClaw
Aug 14, 2015 06:58 PM
92camaroJoe
Aug 13, 2015 06:07 AM
