700r4 to a 350 turbo
Old Sep 3, 2006 | 06:18 PM
saliger64504's Avatar
Car: 1984 firebird trans am
Engine: 383 stroker
Transmission: th350
Axle/Gears: 10 bolt posi with 373 ring and pini
i have a 1984 trans am it has a 700r4 trany in it i would like to replace it with a 350 turbo is it possable to change them out or would i haft to put a nuther 700r4 in it
Old Sep 3, 2006 | 06:22 PM
johnnyboy's Avatar
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
yeah you can put a th350 in your car, should bolt right up to the block, but unless you're dragracing why not just put a rebuilt 700r4 on?
Old Sep 3, 2006 | 06:23 PM
Engine: 383 stroker
Transmission: th350
i am turning my trans am into a street strip car
p.s the reason i ask is because my uncle is a machanit and he said that the tail in to short to bolt up
Old Sep 3, 2006 | 07:03 PM
vortech35091RS's Avatar
Car: 1991 camaro RS
Engine: 350,vortech heads,zz4 cam,3:73 posi trac,edelbrock carb,wiend stealth intake,raven mufflers,hooker supercomp shorty headers and y-pipe.
Transmission: th700r4
No, you'll need to change a few things...I been down that road. I just ended up buying a high performance 700R4 for 1,200. If I would have bought the t350, It was going to be over 1,400 with the tranny and all the mods that would have had to be done.
You would need a different driveshaft (You would need to get your re-length)
You're cross member will need some work
you'll need to buy the conversion kit...I think It was like $132 at summitracing
Old Sep 3, 2006 | 07:06 PM
Car: 1991 camaro RS
Not to mention U-joints and having to get your driveshaft balanced...Dude, just buy another 700r4...there expensive, but they give you the extra gear, and somewhat better gas mileage.
Engine: 383 stroker
Transmission: th350
you know where i can get a high performance 700r4
Old Sep 3, 2006 | 07:10 PM
Car: 1991 camaro RS
Just call your local shops, and tell them you want a rebuilt 700r4 with a shift kit and a high stall speed lockup converter. if you want to spend money one your credit card...Summit Racing - High Performance Car and Truck Parts | 800-230-3030
Old Sep 3, 2006 | 07:12 PM
Engine: 383 stroker
Transmission: th350
the sad thing is i just found out that i haft to rebuild a rebuilt engine in this T/A the engine only had 41 miles on it
Old Sep 3, 2006 | 07:17 PM
johnnyboy's Avatar
jegs, or summit
Old Sep 3, 2006 | 07:20 PM
johnnyboy's Avatar
what happened that the engine needs to be rebuilt?
Old Sep 3, 2006 | 07:22 PM
Engine: 383 stroker
Transmission: th350
i have a rod knocking we though it was the timming cause the timming was off but myuncle was able to time it with out a timming gun or anything kinda flippedme out but i forgot he has been rebuilding cars since he was 12
if any of you have yahoo or aaim drop me a line my aim is saliger64504 and my yahoo is missouri_guy64504
Old Sep 3, 2006 | 07:32 PM
johnnyboy's Avatar
yeah you can time an engine just by hearing the rpm's
Old Sep 3, 2006 | 07:39 PM
Engine: 383 stroker
Transmission: th350
now to a different subject why wont my car move not sure whats wrong with the trany i mean it shifts fine but it just dosnt move forword verry good and it wont make it up a car ramp the guy i bought it from said he had the trany rebuilt any ideas of what it could be
Old Sep 3, 2006 | 07:43 PM
johnnyboy's Avatar
umm, well it's broken lol i dunno you would have to ask someone who knows more, could be a problem with the torque converter
Old Sep 3, 2006 | 08:56 PM
Engine: 383 stroker
Transmission: th350
well i think i found the problem of y the trany was acting funny i had to replace the raidiator in it and had to unhook my trany cooler and it drained the fluid for the trany well i forgot to feel it back up afteri hooked everything back up
Old Sep 3, 2006 | 09:18 PM
johnnyboy's Avatar
well that would do it.
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
camaro11j
Sep 19, 2018 08:49 AM
Eric-86sc
Aug 24, 2015 09:01 PM
crazynights
Aug 21, 2015 06:53 AM
djmarch
Aug 11, 2015 10:22 AM
