Gears....GM 10 bolt...
Old Oct 8, 2006 | 01:55 AM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
Transmission: Built 700r4
I am aquiring a 1991 Camaro RS...
has a 10 bolt rear drum.... the back brakes dont mater much to me... it they bother me, i'll just swap to a 4th gen rear or something later...
my question is, what spline did they originally come with, what series carrier did they originally come with? current gears should be 2.73(or 2.77) not sure...
I am swapping to a 3.42... not a huge difference but enough to make my cruise speed in 5th gear match my engine's cruising rpm...
thanks..
Old Oct 8, 2006 | 05:00 AM
ede's Avatar
ede
28 and 2
Old Oct 8, 2006 | 11:04 PM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
Originally Posted by ede
28 and 2
can i buy a 3 series carrier auburn and install it with a 3 series gear? or will it not fit in the case? thanks...
Old Oct 8, 2006 | 11:15 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
cheaper to find a good used rear end in the gear ratio and posi options you are looking for than spending $600-800 to have a new set installed.
Old Oct 8, 2006 | 11:54 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
a new carrier with new gears will fit. Just make sure you get the 28 spline version.
If you have the tools to install new gears (magnetic base), and are willing to do it yourself, it might be worthwhile.
If you just want the 3.42 ratio, and don't have your heart set on the aftermarket posi, you can always follow xpndble's advice. Not sure of sources for 3.42 gears with a posi, I think the late 3rd gens had lower gear #'s then that, and the V6 cars had the higher ratio but no posi, so...
Old Oct 9, 2006 | 09:23 AM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
I had mine swapped, And Yes I did pay $800.00. I needed to upgrade to a 3 series.
Stock I was a 2 series 2.73. I thought I was told when getting mine done that, a 2 series could only go up to a 3.23.(maybe I'm wrong) And upgrading to a series 3 I could go with a 3.73 or a 4.11. I didnt want to go 2.73 to a 3.23.....I wanted bigger.
4.11 is a little over kill with a 700r4 though. 1st gear is low enough with my 3.73!
Old Oct 10, 2006 | 02:29 AM
Pat Hall's Avatar
3.08's are the highest stock ratio with the 2 series carrier. 3.23's are the starting point with the 3 series carriers.
Old Oct 10, 2006 | 07:07 AM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Thanks Pat, I knew it was something small. 2.73 - 3.08....theres not much difference there. I knew I wanted to go bigger, thats why I went with the series 3 carrier and the 3.73.
With a 4.11, 1st gear would be so short.
Old Oct 11, 2006 | 01:55 AM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
yes i will be replacing the unit myself, not hard at all... installing the spare set of WS6 sway bars and springs i have as well... So its definately not a hard chore..
SRKLEGIN
Sep 8, 2013 09:08 AM
rick90gta
Wheels and Tires
17
Apr 29, 2013 07:19 PM
luvofjah
Apr 28, 2013 01:37 PM
Dyno Don
Southern California Area
37
Feb 14, 2008 10:51 AM
Kingtal0n
Oct 12, 2002 01:27 PM
