U-JOINT HELP, PLEASE
Old Feb 13, 2007 | 08:32 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Ok, I have a 89 Camaro 700R4.Steel Drive Shaft...I got an Aluminuim driveshaft out of a 88 Firebird....Went and bought new back U-joints, the only problem is the ones for the shaft are smaller than the ones for the rearend yoke, or whatever the thing on the rear end is called....Just went to put it in and no go....So can someone tell me the difference, or what U-joint, I should be using???? Brand ??? Part Number???? Other than this the shaft is the same length and all the yoke on the shaft fits the tranny ok....Was the difference in the rear maybe because the firebird had a different rear end than my car..??? Please help, as I really want to use this shaft...It is alot lighter, and probably balanced better....Thanks for any help on this...Tom
Old Feb 13, 2007 | 09:12 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The yoke on your differential takes what's called a 3R u-joint. The aluminum driveshaft uses a Spicer #1310. You need a 1310/3R combination u-joint or a full 1310 u-joint and a 1310 yoke.
Old Feb 13, 2007 | 09:20 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Stephen 87 IROC... Oh no, does that mean i have to change yokes on the rear, or is there really a combination u-joint available????????? Thanks man, im about to pull my hair out.......Tom
Old Feb 13, 2007 | 10:03 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Combination U-joints are available.
Old Feb 13, 2007 | 10:59 PM
AlkyIROC's Avatar
Car: 87 IROC L98
That's why I said OR. There are many combination u-joints available for the common size u-joints. Just go to your local auto parts supplier and tell them you need a 1310/3R combination u-joint.
Old Feb 14, 2007 | 06:57 AM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Ok, thanks alot, I never heard of that, but will check it out..........Tom
Old Oct 27, 2020 | 08:47 AM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Re: U-JOINT HELP, PLEASE
Sorry to bring this thread back from its 13 year nap... During my swap to install a Dana 44 in place of the factory 10-bolt, I couldn't figure out why the u-bolts wouldn't fit over the u-joint bearing cups. Aren't all the joints #1310....?
3R = 1 1/8 = 1.25" cup diameter
#1310 = 1 1/16 = 1.062"
After some searches, I also found this thread, confirming yes, the rear shaft joint is a 3R x 3R. Here are two options for 3R x #1310 u-joints.
AdvanceAutoParts.com - Moog #372 for $22.49
OReillyAuto.com - Spicer 530221X (5-3022-1X) for $39.99
I like cheaper as much as the next guy, and the online reviews said good things about both Moog and Spicer. However, not wanting to skimp on parts that make a real mess if they fail, I spent extra on the Spicer joint. (And next day pick from store 1 mile away, instead of 7 miles.)
Old Oct 27, 2020 | 03:04 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Moog 372C is what I used for my 84 rear and 1LE alumn drive shaft IIRC
Old Oct 27, 2020 | 03:36 PM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Thanks Midias. That chart looks familiar, and should help the next person wondering.
soarestransam
Jun 24, 2017 09:37 PM
n8sz28
May 31, 2011 11:39 AM
anthony714
Feb 21, 2006 09:34 PM
BigWhiteGTP
Aug 31, 2005 06:53 AM
SpRaYd91Z28
Mar 22, 2001 09:23 AM
