Possible cracked flex plate questions
Old Jun 3, 2007 | 06:28 PM
wackytower's Avatar
Car: 1985 Trans Am
Engine: Superramed 406
Axle/Gears: 10 bolt 3:73
I have a tapping noise that sounds sorta like a loose rocker arm but its coming from the TC/ flexplate area. It only does it under load not in nuetral or park. Is this noise something that indicates a broken flexplate? I have done a visual inspection and I cannot see any cracks. The torque converter bolts are tight. Anyone have any ideas? My experience with broken flexplates that they make a terrible sound not just a ticking sound.
Old Jul 23, 2007 | 04:41 PM
wackytower's Avatar
Car: 1985 Trans Am
Re: Possible cracked flex plate questions
Ok swapped out the flexplate and the noise is still there. Any Ideas?
Old Jul 23, 2007 | 07:38 PM
Could be the converter itself.
Old Jul 23, 2007 | 11:19 PM
DNSTA's Avatar
Car: 1991 Camaro RS
Engine: 355
Transmission: 700-R4
Axle/Gears: 4.10
Working on the same problem. The converter was sent back to the manufacturer and I'll know if it was that soon. I also took out the front pump from the trans. I'm going to rebuild it this week and see what happens. I'll let you know. If you find out anything please let me know also.
Old Jul 24, 2007 | 11:02 AM
D3ATH)(TR00P3R's Avatar
Car: 88 Camaro SC
Engine: 305 TBI
Axle/Gears: Posi
Some of the tranny bolts may have worked their way loose, I know that can cause a tap/knock sound. ( i know you checked you tC bolts)
Old Jul 28, 2007 | 06:24 PM
DNSTA's Avatar
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 4.10
Did you ever figure out what was causing the noise? I'm still waiting to get my converter back so I'm not sure what was causing my noise yet.
Old Jul 28, 2007 | 06:29 PM
wackytower's Avatar
Car: 1985 Trans Am
No I havent. My super duper Craftsman low-pro jack took a crap and I have been real busy with work. I am thinking in middle of August I will just take it up to the shop that built the trans.
Old Jul 28, 2007 | 06:40 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
This has happened to me. Turned out that when I reinstalled the auto trans, a bracket that holds the wiring loom at the back of the block dropped down between the engine and bell housing leaving a gap of about 1/8th - 3/16ths between them when tightened down. I kept hearing a "tap tap tap", thought I had a major problem. Loosened the bell housing bolts, installed the bracket correctly and no more tap tap tap.
Old Jul 29, 2007 | 10:54 AM
DNSTA's Avatar
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 4.10
I wish it was that easy for me. I'm half expecting it to be the converter but knowing my luck it will be a broken internal trans part. I'll keep everyone informed. I should know about the condition of the converter early this week.
Old Aug 2, 2007 | 07:44 AM
DNSTA's Avatar
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 4.10
Still waiting on that damn torque converter....
Old Aug 23, 2007 | 06:05 PM
wackytower's Avatar
Car: 1985 Trans Am
OK Its figured out. My original flexplate was bent from when it was bolted to the motor sitting on the floor for 5 years before I installed it. I installed it on the rebuilt motor not knowing it was bent. The guy who inspected my trans said that the converter and front pump had wear/damage and after he seen the flexplate I replaced he said noise and damage was (he was 99% sure) from the bent flexplate.
Frozer!!!
Jan 19, 2024 04:55 PM
evilstuie
Jan 9, 2020 08:29 PM
mhatfield 14
Oct 24, 2015 07:48 AM
1985chevydude
Aug 20, 2015 12:29 AM
redmaroz
Aug 16, 2015 11:40 PM
