what spline of axle's?
Old Jul 5, 2007 | 08:31 PM
fireredz28's Avatar
Car: 1991 RS Camaro
Transmission: th350
Axle/Gears: Ford 9"
I have a 91 rs and i was wondering what spline of axles it has in it? I know that some are 26 spline but i was told they may not all be the same, thanks
Old Jul 5, 2007 | 09:36 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: what spline of axle's?
88 and up are supposed to be 28 spline while older ones are 26.
Old cars get stuff swapped around so you need to check anyway...
Old Jul 5, 2007 | 09:47 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
1990 an up are 28 spline. There's a slim chance a 1989 model will have 28 spines but most only have 26. It depends on the actual build date. All the earlier ones have 26 spline.
You have 28 spline.
Old Jul 5, 2007 | 10:06 PM
fireredz28's Avatar
Car: 1991 RS Camaro
Transmission: th350
Axle/Gears: Ford 9"
Ok now for my next question, what spline of axles would a 4th generaion camaro have? I have a spare posi carrier i was going to swap in if it will fit is why im asking, thanks
Old Jul 5, 2007 | 10:08 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The 4th gens have 28 spline axles. The posi unit should fit as long as its "series" matches your gears. 3.08 and lower are 2-series and 3.23 and higher are 3-series.
Old Jul 5, 2007 | 10:13 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
i did a search with car-part.com and saw a 1991 with 26 spline
with as old as the cars are now its going ot be hard to say which it is, youll have to look to be certain, who knows if it is still original, or correct for the year and so on
good luck
Old Jul 5, 2007 | 10:17 PM
fireredz28's Avatar
Car: 1991 RS Camaro
Transmission: th350
Axle/Gears: Ford 9"
Thanks for the fast responses and great help, i have everything i need as long as whats in my car now is actually a 28 spline axle, thanks again for the help!
Old Jul 5, 2007 | 10:35 PM
7.0 camaro's Avatar
Car: camaro
Engine: 383
Transmission: 350 turbo
i have a 91 rs. it had 28's. i run a torsen unit with a 3.42 gear.
Old Jul 6, 2007 | 07:51 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Nothing saying the original 28 spline axle broke and the owner couldn't find a replacement so he swapped an earlier diff or axles/carrier into the 91.
You could just as easily have a 82 with 28 spline axles. It's a simple swap.
cheesehomer
Dec 31, 2015 08:48 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
usafirebird
Sep 29, 2015 11:58 PM
Numbah-1
Sep 20, 2015 09:31 AM
rudolphschenker
Sep 4, 2015 02:41 AM
