WC T5 leaks at VSS
Old Aug 22, 2007 | 09:16 PM
palric's Avatar
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
WC T5 leaks at VSS
Hey All,
I have a WC T5 tranny which started to drip at or around the VSS.
It looks like it is coming from the VSS siwtch plug area. For a leak it is pretty clean eg: not dumping out fluid everywhere it just drips alot overnight when I park it.
I don't see any cracks. The tranny was rebuild and put back in. Is it [possible to screw up the VSS and cause a leak?
Is a leak at this point common on a WC T5? Any known fixes?
thx
Old Aug 22, 2007 | 09:49 PM
Re: WC T5 leaks at VSS
Yes it is very common.
Could be the VSS iteslf, or it might just need a new O-ring around it.
Old Aug 22, 2007 | 11:26 PM
Synful's Avatar
lol wtf
how come you never mentioned this to me in my post
it's like right above where the leak is coming from and i didn't even know it was a suspect
Old Aug 23, 2007 | 05:55 AM
Because in your post, you said
Dripping from center of T5 gearbox.
can only be coming from the front somewhere....
When the VSS leaks, it will drip off of the VERY TAIL END of the trans, from back there where the VSS is about a foot BEHIND the center, and in the direction the fluid goes in. It won't ever make it to the center of the case because even if it manages to go toward the front somehow, it'll drip off the trans mount instead.
Therefore it's not likely AT ALL in your case.
Old Aug 23, 2007 | 07:56 AM
palric's Avatar
yup
VSS is in the rear portion. Mine has a minor drip right coming from between the black plug in switch and the round thingy right beside it.
Its high enough in the tranny it will eventually stop dripping or the drip is now just a trickle. *NOT* a good idea to drive a leaky T5 so mine is heading into the shop today.
Old Aug 23, 2007 | 09:09 PM
Synful's Avatar
do either of you have a picture of where the VSS is located?
Old Aug 24, 2007 | 05:30 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Rear of the cluster for you. Check the following link:
https://www.thirdgen.org/forums/elec...cle-speed.html
JamesC
Old Aug 24, 2007 | 04:53 PM
palric's Avatar
figured out what caused the leak
the bolt came out of the tq arm mounting to the tranny which caused the end to whack the tranny which broke the VSS which led to th eleak.
gotta luv the tq arm setup.
Old Aug 25, 2007 | 07:26 PM
Synful's Avatar
edit - wtf wrong thread sorry
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
RS Reaper
Oct 17, 2018 07:52 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
aaron7
Sep 30, 2015 09:15 AM
