Guy's I need to know what tranny I have, It is a t-5 but what model.
Old Sep 13, 2000 | 05:16 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
It is from a 88 iroc is it a m39, or is it somthing else there are 2 more choices but I for got what they where.
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Moroso Blue max wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old Sep 13, 2000 | 06:41 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
What do you mean which model? You mean world class or not? If its from an 88 car, it's a world class.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Sep 14, 2000 | 06:43 AM
BLACK Z's Avatar
Car: 86 Z28
I know it is a world class but when I went to order some parts they say they need to know if it is a m39 or the are 2 more I forgot what they where, the m39 shares all of the parts with another number but the 3rd number has it's own slave, clutch ball and so on, The other 2 numbers start with a m to.
Old Sep 14, 2000 | 09:58 AM
Kevin91Z's Avatar
My RPO codes for my trans are MK6 and MM5, I have both of those. But on the trans itself the number is DKL. Do you know if you have the 2.95 first gear or the 2.75 first gear? Mine is the 2.75 first gear. Another trans I have with the 2.95 first gear said DKB on it.
Old Sep 14, 2000 | 12:09 PM
blak92!'s Avatar
On the drivers side of the transmission there should be a tag. This tag identifies the transmission. With that number you can reference the year it was intended for and its respective ratios. My transmission id tag has the number (1330-196 or 5) or close to that which identifies it as 2.95 1st gear .63 5th gear for the '91 model year. '90 - '92 2.95 was standard for the TBI and most TPI motors, some '90-'91 and all'92 TPI's had the close ratio 2.75 trans with .75 5th gear which has "in theory" a better torque rating because of its numerically lower (multiplies torque/energy less), therefore it should be the strongest T5.
I have all the info available of T5 id numbers from '83 to '95 and will post in on this board or email it to Kevin. The list icludes all displacements, WC or non-WC, and gear ratios.
THe list is most useful when shopping for a junk yard trans. If I did not have the info, I would have been screwed 3 different times from local junkyards. Every trans they would come up with was a non-WC.
Old Sep 14, 2000 | 12:58 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
blak92! could you email me a list of that to? anthonym@bcgroup.net.
89 GTA 350 5-speed
Jet hot coated SLP headers,flowmaster force 2,no cat's,SLP cold air,MSD 6al,jet chip stage 2,march pulleys,ported plenum,air foil,B&M ripper shifter,180 stat,alston SFC,spohn LCA relocation brackets,MAT relocation kit,free mods.
0-60 5.48s
E.T. 14.02@98.9MPH (corrected)
Old Sep 14, 2000 | 01:37 PM
Kevin91Z's Avatar
Email that to Dirk as a tech article, or for the FAQ. That sounds like good info!
Old Sep 14, 2000 | 10:32 PM
BillyB4C's Avatar
blak92!....Can you also send me the list?...bryson@texas.net
Billy
92 B4C 305TPI T5
Texas Spokes Sports Car Club #63 ESP
73 Z28
Old Sep 17, 2000 | 09:39 AM
BLACK Z's Avatar
Car: 86 Z28
so does anyone know what would be in a 88?
Old Sep 19, 2000 | 07:34 AM
blak92!'s Avatar
https://www.thirdgen.org/messageforu...ML/000124.html
spaigo
Aug 21, 2015 07:46 PM
crazynights
Aug 21, 2015 06:53 AM
Street Lethal
Aug 14, 2015 08:25 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
