tranny probs.
Old Sep 11, 2000 | 06:23 PM
SlowCamaro88SC's Avatar
tranny probs.
ok here's the prob.
the tranny is an otherwise new 700-R4, rebuilt w/ B&M parts all over and a shift kit. I have a v6. It shifts too early out of first, @ 5200 RPMs instead of 6000 RPMs, and doesn't want to shift into 3rd unless I let off the gas. So in effect the engine will keep going past 6000 RPMs and lot shift at all, unless I let off the throttle. That really slows the car down. I want to sell the car because of this problem. I am 18, and do what I can, but I'm no master mechanic. Someone help!
Flame Red 88' Camaro SC, Rare Spoiler
2.8, 3.42 Open Rear
TCI 3200 RPM Stall TC
B&M Transkit
Sawed Airboxes
BFG Radial T\A's
235/60/15 Front
275/60/15 Rear
Custom Painted Stock "Z/28" Rims
New Dynomax Catback
Le Bra
IROC Taillights
Foglamps
83 Z/28 Hood (w/ Functional Scoops)
Aftermarket Pedals
And of course, a loud stereo
Old Sep 12, 2000 | 01:53 PM
FastBroker's Avatar
I'd call B&M Tech and get their opinion(s).
Old Sep 12, 2000 | 02:16 PM
89ProchargedROC's Avatar
did you play with the governor springs? we dont even bother with that anymore at my trans shop. Too hard to get right, people come back all the time. Put it back to stock shifting and shift it yourself.
Old Sep 12, 2000 | 05:53 PM
no the governor springs are stock. my tranny was so bad when it went that the "CORE" is from a '88 blazer w/ a 2.8. the only thing savable from the original tranny was the reverse sunshell. Even if I manually have the tranny in first gear it will still shift out @ 5200. so then, I will be in second gear, with the shifter in 1st.
I got a B&M transkit, not a tranny from them, but the transkit has like all the parts there anyway. So they were all replaced. I've heard even though I have a V6, it should shift real hard out of first, and possibly chirp the tires, but I'm not even close.
By the way, here's my new sig.
Bright Red 88' Camaro SC, Rare Spoiler
2.8, 3.42 Open Rear
B&M Transkit
Sawed Airboxes
Ground Effects Red in front, fade to silver on sides
New Dynomax Catback
IROC Gages
IROC Taillights
Foglamps
BFG Radial T\A's
235/60/15 Front
275/60/15 Rear
Old Sep 13, 2000 | 08:27 PM
nickd's Avatar
Have you tried adjusting the tv cable ?
Old Sep 14, 2000 | 09:41 PM
yeah, it's set perfect, but when set right, it still shifts wrong, no matter what it won't shift any differently.
Old Sep 15, 2000 | 04:21 PM
nickd's Avatar
I had a similar problem with a B&M kit in my 700R4. It would shift late and sometimes not at all.
The problems went away after I had removed the B&M kit.
Old Sep 17, 2000 | 05:44 PM
remove the B&M kit?
um, no. doesn't sound right to me.
is it possible to remove it?
i don't think I can remove the transkit.
it kinda is like 70% of my tranny.
Old Sep 22, 2000 | 07:13 AM
nickd's Avatar
Sorry, what I was referring to was the shift kit. I should have specified that in my last post above.
Considering you said your tv cable is adjusted perfect and assuming you checked the governor, I would start looking at the valve body which is what controls your transmission.
Old Sep 22, 2000 | 05:50 PM
the wierd thing is, the car feels quicker and faster, maybe from 5200-6000 it's making less power than it is around 3100-3500?
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
