Mini Spool for a 10 bolt
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The 7.5 mini spool available is for 26 spline axles. They don't make one yet for 28 spline axles. As long as your 85 still has factory axles then the 26 spline mini spool will work.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
LS6 Big Block buildup now in progress
Best results before the engine blew up
Best ET on a time slip: 11.857
Best corrected ET: 11.163
Best MPH on a time slip: 117.87
Best corrected MPH: 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
Best 60 foot: 1.662
I thought I read that mini-spool is only for dirt track use otherwise I would have already bought one. I'd really like to have a full spool for my '91 bird but I haven't been able to track one down.
Later,,, Matt
Dirt Late Model racer and Third gen lover.
91 V-6 bird with 406 in process.
Later,,, Matt
Car: 87 IROC L98
They only say a mini-spool is for dirt track because having a locked diff on pavement is hard on tires and axles. For drag racing a mini-spool will work but still puts a lot of stress on the crosspin.
A full spool isn't available from anyone for the 10 bolt 7.5 diff. It's just too small a dif for true performance. Even though there are many 10 bolts out there, the manufactures don't feel it's a strong enough market to produce a 7.5 full spool. The closest thing you'll be able to get is a 26 spline mini-spool or upgrade to 28 splines and have the spider gears stainless welded properly. Welding isn't approved by the NHRA but I know many cars that have had welded gears for many years. 4x4's will usually weld the gears in the front diffs. They abuse the trucks more than we do the cars and the diffs survive.
Saxondale
Exterior Parts Wanted
Sep 7, 2015 06:11 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
