700R4 tranny problems
Old Nov 10, 2000 | 07:36 AM
Irockin's Avatar
I have an 86 Iroc 5.0 tpi w/700R4 trans. My transmission will hit all four gears, but it will not go into overdrive. I have installed a new 700R4, but I am having the same issue. My engine revs at 3000 rpm at 70 mph. Please help
Old Nov 10, 2000 | 03:25 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I'm a bit confused by what you mean when you say it will "hit all 4 gears" but "won't go into overdrive".
Are you sure it's not going into OD? There's a thing called a TCC (torque convertor clutch). It puts the torque convertor into lockup. If the TCC does not engage, it can seem as if there's no overdrive.
Have you done this: Next time you're doing 70 and the stick's in OD, move it to "D". Do the RPM's change?
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Nov 12, 2000 | 06:22 PM
pianiy's Avatar
I'm not so sure you want to try downshifting to 3rd at 70 even if it IS in 3rd... maybe a lower speed like 55 (it should be locked up by that time)
'91 Firebird
305/TBI/700R4/T-tops
Mods: Catco high flow cat - B&M Shift kit - Taylor 8mm Spiro-Pro's - ACDelco Rapidfire Plugs - K&N Air Filter - Trans Am tail light conversion
Stereo: Pioneer DEH-P8200R - Pioneer 6x9's - Kenwood 8" Tube
'91 Pics
'87 Firebird
2.8L/MPFI/700R4/220K Miles on its original, never been rebuilt engine!
Car being parted and sold, just ask what I have.
'87 Pics
Old Nov 12, 2000 | 07:36 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
try bypassing the TCC,short the pins in your ALDL connector(top left & top right) together with a coule pieces of wire and a switch,engage the switch after 1st gear the TCC should grab tight. this will also eliminate the "syncromesh" that takes place from D-OD.
Old Nov 12, 2000 | 09:24 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
"Synchromesh" is in manual transmissions. I have been around 4L60's for a good while, and the only thing that even comes close is a "synchronized shift" wich occurs at the 2-3 shift, when the band releases and the 3-4 clutches applies simultaniously.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Ported Plenum,
TB Coolant Bypass,
SSM SFC,
Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims.
'97 Bonneville SSE
Old Nov 14, 2000 | 07:58 AM
Irockin's Avatar
Junkyard, you were right. Your suggestion worked. The ECM gave me a code for the VSS and I read that that directly effects the TCC as you mentioned. I will replace it and hopefully that will solve my O/D problems....Thanks.
Old Nov 14, 2000 | 10:55 PM
Engine: 2.2
yeahhhhhhhhh! I love fixing things! I learned that from one of Ed Mahers posts a year ago, he claims it gets him another .2 on the 1/4 mi,even though its not the best thing for the transmission. I still have the switch under my dash, Its kind of fun to turn it on once and a while.
thank you GMtech,learn somthin new every day,but I swear it says "synchromesh" OD gear in one of my tech manuals.
Old Nov 15, 2000 | 10:05 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I just used that lockup switch at the track. It dropped 0.18 off my time, and gave me an extra 1.7 MPH in the 1/4!
[edit] That was with a lower-than-usual launch speed too; I only went to 1800 rpm, instead of my usual 2000-up. It started raining before I could try a higher launch.
[This message has been edited by TomP (edited November 15, 2000).]
camaro11j
Sep 19, 2018 08:49 AM
Thornburg
Aug 25, 2015 01:46 AM
spaigo
Aug 21, 2015 07:46 PM
TreDeClaw
Aug 14, 2015 06:58 PM
drathaar907
Aug 6, 2015 04:20 PM
