Speedometer for TH350
Old Oct 5, 2008 | 10:22 PM
AlabamaGuy's Avatar
Car: 1991 Camaro RS
Engine: 454
Axle/Gears: 2.73 open
I bought a car that already had a TH350 swapped into it (91 RS). How can I get my speedometer to work?
Old Oct 8, 2008 | 04:05 PM
DAVEY420's Avatar
Car: 85 IROC Z
Transmission: TCI TH350 TCI 2400 STALL
Axle/Gears: 3.42 WORN OUT POSI
Re: Speedometer for TH350
Let me know if you ever figure it out. I swapped one in 6 mths ago and haven't had a speedo since.
Old Oct 13, 2008 | 07:33 PM
bluechev's Avatar
i believe if you call tci they will tell you what gears to put in the tailhousing depending on what gear ratio and tires size you have
Old Oct 14, 2008 | 07:44 PM
AlabamaGuy's Avatar
Car: 1991 Camaro RS
Engine: 454
Where would I buy the gears?
Old Oct 14, 2008 | 08:38 PM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Are the 91's cable speedo's? When i put the TH350 in my car, my speedo cable screwed right on to the housing...
Old Oct 14, 2008 | 08:54 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Axle/Gears: Ford 9in 4.10
91-92 or maybe 90-92 is electronic
Old Oct 14, 2008 | 10:09 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
If it's a cable driven speedo, just hook it back up. Could probably swap in the plastic gears from the old trans. If it's electric, they make things that use the gears and output an electronic signal.
Old Oct 14, 2008 | 10:11 PM
AlabamaGuy's Avatar
Car: 1991 Camaro RS
Engine: 454
SO then, will I need an aftermarket cable driven speedometer? Should I just start looking to custom make a cluster? Or can you run am electronic speedo to a TH350? I was wanting to do an all digital dash but the TH350 may make that impossible.
Old Oct 14, 2008 | 10:20 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
What fast82z said, they sell adapters to convert it
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
