Tranny Help
Old Oct 19, 2008 | 05:07 PM
joeatl's Avatar
Tranny Help
Hello.
I just bought a 86 transam with a 5 speed tranny. It had a 305 in it with bad piston rings. I drove it for like 4 days, then had a motor shop drop in a 350(not sure hp rating, has torqer heads, not sure the other spec) It was a crate 350. But now when i drive it sometimes, when i am hallin *** from a light. When i go to shift from 2nd to 3rd the tranny smokes a lil bit out of the shifter boot. What can cause that? Shifting too late? Too much HP for tranny? Tranny needs rebuild?
Old Oct 19, 2008 | 09:58 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Tranny Help
I doubt it's the trans, unless it doesn't have any oil in it. I think it's coming from your engine and blowing on the exhaust at high rpm.
Old Oct 19, 2008 | 10:55 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Re: Tranny Help
it's probably from the clutch
Old Oct 20, 2008 | 01:05 AM
joeatl's Avatar
Re: Tranny Help
what do you mean from the clutch? they said it had plenty of meat on it. Also i am new at driving a stick......hehe Any advice on how to make it not do this. What happens if you go from second to 5th? maybe i didnt hit 3rd right, maybe rev'd to high?
Old Oct 20, 2008 | 02:02 AM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
Re: Tranny Help
next time it happens give it a good wiff to see what it smells like, exhaust? burnt clutch disc? thatll be a dead give away. i also have a problem where for some reason it gets really warm around my shifter, and alot of hot air blowing from it. but the only thing i know about my situation is that its not the trans because its an automatic, so i know im not burnin clutch.
Old Oct 20, 2008 | 07:03 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Tranny Help
Check the boot for installation problem, tears, etc.
JamesC
Old Oct 20, 2008 | 04:32 PM
Re: Tranny Help
JamesC
well mines is an automatic so i dont have a boot
Old Oct 20, 2008 | 06:23 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Re: Tranny Help
it's more likely that it's too much horsepower for the clutch... or you REALLY suck at driving a stick. I couldn't imagine smoke coming out of a transmission. You're the only one who can really tell where the smoke is coming from, like gurkgurkgurk said, by how it smells.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
