Reverse and 1st only!!
Old Apr 11, 2009 | 11:14 PM
beaner67's Avatar
Car: 90 RS
Engine: LT-1 350
Transmission: Auto 700R-4
Just got done rebuilding my 350. Started her up today and when I went to take her for a drive, I only got first gear. She has an auto 700R4 in her. Gunna check the TV cable tomorrow, but would really like any suggestions anyone can think of. Park, Reverse, and Neutral are all where they should be but for some reason that tranny isn't shifting out of first...any ideas would be a lot a help.
-G
Old Apr 11, 2009 | 11:23 PM
Knuckles_up's Avatar
Car: 1985 Camaro
Engine: V6
Re: Reverse and 1st only!!
May be stupid, but did you double check that you have everything plugged in where it needs to go? Maybe the sensor wire that tells the tranny to shift at X rpm got damaged or just isn't plugged in.
Old Apr 11, 2009 | 11:37 PM
beaner67's Avatar
Car: 90 RS
Engine: LT-1 350
Possible.... I'll have to double check that tomorrow. I know that the two wire connectors that connect to the tranny were slightly damaged... taped them up, but maybe one of them got pulled out when we tried to fix it.... have check on that
Old Apr 11, 2009 | 11:39 PM
Car: 1985 Camaro
Engine: V6
Also make sure that the connectors are clean of grease and dirt when you check them. They could be not getting a good connection.
Old Apr 11, 2009 | 11:44 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
have you checked the govenor/gear
-G
Old Apr 12, 2009 | 12:13 AM
beaner67's Avatar
Car: 90 RS
Engine: LT-1 350
What govenor/gear? Is this something on the tranny? The engine is an older engine out of an 85 pick-up that does not use ECM..... not sure if that would change any of your suggestions
Old Apr 12, 2009 | 09:40 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
700R4s are not electronic shift. Nothing electrical tells them to shift into the next gear. There is a single electrical connector on the left side of the case that allows the ECM to control the converter lockup.
antoine poined out correctly that what controls the shift, and also shift RPM, in a 700R4 is the governor. There is a dome shaped cover on the left side of the case. You have to pry that cover off with a screwdriver, maybe some hammering; it will be a pain in the @$$. Underneath is the governor. It's a little weight and spring affair with a gear on the end. The gear can become brittle with age and break apart. If the gear is damaged replace it. Also, make sure that the wieghts inside move freely. Silicone the cover before driving it into the case with a punch and hammer around the ring (like driving in a seal).
If the governor is fine the only other thing I can think of that would cause this is something inside the trans. It could be burned up clutches, something wrong in the valvebody, or something else. In my K5 I broke the end off the internal reaction carrier and it only had low and reverse. I was a bit suprised when I tore down the trans and found that. I couldn't believe that it would move at all, but it did.
Old Apr 12, 2009 | 10:37 AM
beaner67's Avatar
Car: 90 RS
Engine: LT-1 350
Alright,
Well, I'll be going down in an hour or so to start working on it. I'll check into that governor situation. Hopefully it isn't to difficult of a job to check into... I'll let you all know
Old Apr 12, 2009 | 03:59 PM
thunder-lips's Avatar
Car: 1989 Formula 350
Engine: building a 383 as of Feb. 09
Transmission: 700 R4, B&M shift kit
Axle/Gears: 3.23?
I found it helpful to support the trans and take off the crossmember to get to the governor. Also to put the cover back on use a LARGE C clamp and you will save alot of time.
Old Apr 12, 2009 | 11:51 PM
beaner67's Avatar
Car: 90 RS
Engine: LT-1 350
Hey everyone, just wanted to let you know I got it figured out. Had some serious reconfiguring to do with the TV cable. I still need to adjust it a bit to get her just right, but thankfully I didn't have to get into the governor. I drove her home today (was working on her at a shopt 2 hours from my place) and she ran beautifully..... can't wait to get her fully broken in
db057
Apr 28, 2019 07:45 AM
Veaceonee
Sep 29, 2016 08:15 PM
84redta
Sep 19, 2015 09:58 AM
scottmoyer
Sep 7, 2015 07:06 PM
