2nd gen 10 bolt
Old Nov 22, 2001 | 08:57 PM
arthur's Avatar
2nd gen 10 bolt
Can anyone shed some light on the strength of the 2nd gen 10 bolt. I think it has an 8.5" ring gear. Also what is the width of the 3rd gen rear, axle hub to axle hub? Thanks.
Old Nov 22, 2001 | 09:31 PM
SoCo80p's Avatar
the 2nd gen used the 8.5 ten bolt correct, it is VERY strong (just a little under the strenth of the 12 bolt many 10 second cars useing them) but it will not fit a 3rd gen as the 2nd gens used leaf springs and the 3rd gen went to a 4 link setup
Old Nov 22, 2001 | 09:53 PM
arthur's Avatar
My plan is to re-weld the 3rd gen brackets onto the 2nd gen, along with a setup for the torque arm.
Old Nov 22, 2001 | 10:03 PM
arthur's Avatar
My plan is to re-weld the 3rd gen bracketry onto the 2nd gen axle, and setup something for the torque arm. I know the 2nd gen is 55.25" from axle hub to axle hub, so to find out it's the same would be good, narrower, ok, wider, bad, unless differnt wheel offsets are used. Thanks TempesT68.
Old Nov 22, 2001 | 10:26 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
<font face="Verdana, Arial" size="2">3rd gen went to a 4 link setup
</font>
Do you even own a 3rd gen? Look underneath!
Old Nov 22, 2001 | 11:38 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
If you find some practical way to attach the torque arm to the 8.5" 10 bolt housing you could make a lot of money since any GM diff could then be used.
Since you're going to try to attach something to a cast housing I doubt it will work very well or end up costing more than buying an aftermarket 12 bolt or 9".
The 2nd gen diff is also wider than a third gen. Do some measurements before commiting to a diff that you might not be able to use.
Axle to axle a third gen is something close to 61 3/4" wide.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block (times are for the current engine)
Best ET on a time slip: 11.447 altitude corrected to 10.99
Best MPH on a time slip: 119.42 altitude corrected to 124.86
Altitude corrected rear wheel HP: 493
Best 60 foot: 1.586
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Nov 22, 2001 | 11:46 PM
arthur's Avatar
I would measure the dimensions. But at the moment, them being project cars, I don't have the luxery. I even have a 9bolt sitting in the the garage, but I am away so that's not going to work either. I have been scouring the net trying to find the measurements is all. My question is simply this. Why spend $2500 or whatever on a Currie f#rd 9", when you may be able to get the same strength with a $150 initial purchase.
Old Nov 26, 2001 | 12:17 AM
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Pound for pound (ok kilo for kilo) the 9 bolt is much stronger than the 10 bolt. Previously, parts for the 9 bolt were none existant, but that has changed. I currently offer 9 bolt gear sets from 3.2x to 4.10 and new series 3 posi carriers. Other stuff is on the way
Miles
88 427 Big Block Camaro
(Best 1/4) 12.18 @ 113mph 1.75 60ft
(Best 1/8) 7.76 @ 94mph 1.72 60ft
Currently installing 3.73's into my 9 bolt (YES, it is a 9 bolt & YES they are 3.73's, not 3.70. I currently have 4.10 gear sets and new series 3 posi carriers for sale for 9 bolts )
www.koolmeister.com
Old Apr 28, 2005 | 02:48 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Bringing this sucker back from the dead, so how wide is a 2nd gen 10 bolt?
Old Apr 30, 2005 | 12:49 AM
Drakar's Avatar
wow you sure did ressurect this one.
www.nastyz28.com
they got a section on rearends including wide and so on.
Terrell351
Jun 13, 2021 01:13 PM
tricky1
Aug 23, 2015 01:17 PM
Elliswon
Aug 10, 2015 12:33 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
