Australian 9-bolt questions???
Old Dec 4, 2001 | 01:49 PM
fast89's Avatar
I have an 1989 Pontiac Formula 350 with an Australian 9-bolt 323 rearend. I would like to upgrade to 373.
Where can I find one inepxensively?
What is needed to make this happen?
Do I need to change housing?
Your help would be greatly appreciated. Thanxs.
1989 Pontiac Formula L98 Ported Plenum, Edelbrock 6085 Heads, Edelbrock HI-FLO Intake, BBK 52MM TB, Edelbrock TES, FlowMaster 3" Exhaust, Dual Cats, 3.27 Gear, CompuCam 2032 Cam, 1.5 Rollers, Ed Wright FastChip, Accel Super Coil, MSD 8mm Wires, 2500 stall, servo and TransGO.
Old Dec 4, 2001 | 05:26 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
9 bolt parts inexpensive, that's a good one
I have 3.73's for 9 bolts for $295 (other ratios also available). Becareful of others claiming to have 3.73's, they are all the weaker 10 tooth 3.70, not the stronger 11 tooth 3.73. You will also need an install kit, cover gasket and pinion seal and I have that available for $165. No you don't have to change the housing or the carrier if you have a 3.27 carrier. It will support upto (and including) 4.10 gear sets.
Miles
88 427 Big Block Camaro
(Best 1/4) 12.18 @ 113mph 1.75 60ft
(Best 1/8) 7.76 @ 94mph 1.72 60ft
Currently installing 3.73's into my 9 bolt (YES, it is a 9 bolt & YES they are 3.73's, not 3.70. I currently have 4.10 gear sets and new series 3 posi carriers for sale for 9 bolts )
www.koolmeister.com
Old Dec 5, 2001 | 09:49 AM
Brandog87GTA's Avatar
Where can you get those gears for that price at?
Bright red 87 GTA with I have stock 3.27 gears,2200 stall,B&M shift kit, TRW forged 9.75:1 pistons,comp cams pushrods, edelbrock valvesprings, 462 camel hump heads with 2.02in/1.60ex redrilled for angled plugs, 3 angle valve job, ported and polished, performer RPM intake, mallory fp regulator, edelbrock 750 CFM carb, hei ignition(new) with 40,000 volt coil,No cat, flowmaster 1 chamber mufflers, hedman 1 5/8 full length headers, edelbrock cam with 488/501
Best Run 1/8 mile 8.62 at 84MPH on street tires, Consistantly run 8.8. 60 foot times 2.3
Old Dec 5, 2001 | 10:39 AM
fast89's Avatar
88 427 Camaro: Should I go up to 410 gear instead of 373? Do you have 410 gears? Is there a big difference from 327 to 373? This car is not a daily driver, but I would like to drive it on the road as a street car.
Sorry for so many questions, but I am new to this gear stuff. Is it a difficult job for a novice mechanic?
I do not know what else to do to make this car perform better than to replace rear gear.
Old Dec 5, 2001 | 12:27 PM
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
I have the following 9 bolt gear ratios available (ie for sale) for the price of $295, 3.45, 3.73 and 4.10. Install kits are $165. Series 3 posi carriers are $445.
If you have an overdrive trans, the 4.10 would be a good choice. If you don't have overdrive, I would stick with a 3.73. Just my .02 since you asked.
Miles
www.koolmeister.com
Old Dec 5, 2001 | 01:06 PM
fast89's Avatar
Miles: Do I need a series 3 posi carrier?
Is this gear very difficult to install?
Tony
Old Dec 5, 2001 | 01:07 PM
fast89's Avatar
Tony
Old Dec 5, 2001 | 04:56 PM
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
3.27, 3.45, 3.73 and 4.10 ratios all use the same series carrier (aka series 3). It looks like you currently have a 3.27 gear so you should have a series 3 carrier already. Hence you would only need the gear set and the install kit.
Installing gears is usually best left to a shop (or someone that has done it before) unless you have all the special tools. A shop will be $100-200 for an installation.
Miles
www.koolmeister.com
Old Dec 5, 2001 | 11:05 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Hey miles! How do I get my hands on a set of these? I wnet to your website thinking that might be where to get them but didn't see anything. Do you just operate by email, or phone? I may need some 3.73's after I get the new engine installed (Hopefully soon, it's been about 2 years in the works! I hate having bills!)
Thanks!
Also, I know it's been addressed here before, but how muah power will they hold up to in stock configuration? I plan on driving it, but not abusing it, and an occasional trip to the strip with the engine listed in my sig.
Working on:
'84 Z28 LG4 305 with 209,000 original miles!
Dual electric fans (from a formula).
9 bolt posi disc rear with 3.27 gears.
145 MPH IROC Speedo
430 HP 350 (ZZ430) Coming soon! (Building it myself, so I don't get those AWESOME valve covers!)
Starting to look like the Kicker poster child!
ASE Certified Master Tech
+ L1 Advanced Engine Performance
+ X1 Undercar Specialist
And....A sig. that's getting way too long!
[This message has been edited by JP84Z430HP (edited December 05, 2001).]
Old Dec 6, 2001 | 12:43 PM
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
I should have a new web page up with all the details over the holidays. Just haven't had time to finish it lately, so right now email is the best way.
How much stronger???? These are OEM tooled gears made by the original manufacturer (until they sold it off recently), so the strength of these gears is the same as OEM. (I will have some other 9 bolt stuff available after the first of the year too.) I have been running a 9 bolt behind my big block for 3 years now (first with the 3.27, then the 3.73 (NOT 3.70)) and pulling low 1.7x 60 ft times. I think if they are built correctly and maintained properly (ie not worn out) they will hold 1.6x times consistantly (without a trans brake or 5k clutch dumps).
Just send me an email when you are ready.
Miles
www.koolmeister.com
Old Dec 7, 2001 | 05:38 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Is it true that the 9 bolt posi unit is weak?
Old Dec 7, 2001 | 06:10 PM
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Ummmmm, it was the high performance option rear. It is a good bit stronger than a 7.5 or 7 5/8 10 bolt but not as strong as a 9 in or 12 bolt. Mine has been holding up to my big block for 3+ years now.
Miles
www.koolmeister.com
Old Dec 8, 2001 | 03:02 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
I'm refering to just the posi unit. I've read many times that the posi units in the 9 bolts "burn out". Do the 9 bolts have a "clutch" style posi or a "cone" style? I have a 3.27 9 bolt in my GTA and I honestly know nothing about it.
Old Dec 8, 2001 | 08:02 PM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
Miles - what all is included in your install kit?
Old Dec 9, 2001 | 12:06 AM
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
The 9 bolt posi unit is actually much stronger than a 10 bolt as the 9 bolt has 4 spyder gears vs 2 in a 10 bolt. The 9 bolt is a cone style posi.
The install kit includes everything needed for a gear swap and/or a carrier swap (Timken pinion & carrier bearings and races, shims, crush sleeve, ring gear bolts, gear marking compound, silicone, pinion seal, rear cover gasket, install instructions)
Miles
www.koolmeister.com
Old Dec 9, 2001 | 01:59 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
<font face="Verdana, Arial" size="2">Originally posted by 88 427 Camaro:
</font>
That's what I was looking for. Thanks
Old Dec 10, 2001 | 12:47 AM
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Sorry
88 427 BBC Camaro
7.76 @ 94 (1/8 mile) 10/01
12.18 @ 113 (1/4 mile) 10/99
I have brand new series 3 9 bolt carriers and gear sets to 4.10 available for borg warner 9 bolts. Check my web page for more info.
http://www.koolmeister.com
[This message has been edited by 88 427 Camaro (edited December 09, 2001).]
Old Dec 10, 2001 | 02:16 PM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
Are there options for a 2.77 rear?
Old Dec 10, 2001 | 05:38 PM
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Only to upgrade it to a series 3 posi unit. Sorry.
Miles
88 427 BBC Camaro
ZMWojnar
Brakes
May 12, 2019 10:43 PM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
