T56 aftermarket slave/master cylinder
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
Does anyone make an aftermarket slave/master cylinder/reservoir? Like the pre-bleed GM unit?! Thanks.
Robert
Robert
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
Re: T56 aftermarket slave/master cylinder
Here is the one I have, it works really well:
http://www.tick-performance.com/tick...aulics/#master
I think RAM makes an adjustable master as well
Car: '91 LS6/T56/9"
Engine: LS6
Aww man, that's for LSX transmissions. I should have specified that I have an LT1 T56. Anyone make hydraulics for that trans?
Master's are interchangeable the slave is what changed through the years
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Mcleod makes replacement master and slaves.. Pricey...
139001 - Metal adjustable master cylinder with hardware for 93-02 F-body
139024 - Metal Slave cylinder for pull type clutches
Summit doesn't list the slave.. Maybe discontinued now??
Car: '91 LS6/T56/9"
Engine: LS6
Yeah I saw that.........$300+ for the master..............no thanks! The GM assembly will do just fine.
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
I bought the pre-bled LT1 T56 hydraulic assembly here.
Car: '91 LS6/T56/9"
Engine: LS6
Car: '91 LS6/T56/9"
Engine: LS6
camaro1185
Oct 26, 2015 06:51 AM
topteam54
Oct 6, 2015 12:21 AM
