Auto to Manual Help Please
Car: 1992 CAMARO RS 25TH ANNIVERSARY
Engine: 3.1 V6
Transmission: AUTOMAGIC
Axle/Gears: STOCK
I have a 1984 camaro and i want to switch from a auto tranmission to a 5 speed. I have the auto in now and need some help for the other parts needed in order to switch it over. I am now mechanic, show i try to do this myself or have a garage do it. Thanks for any help.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Engine: 3.1 V6
Axle/Gears: STOCK
Re: Auto to Manual Help Please
if i buy a conversion kit will it have all this in it? is it cheaper buying a conversion kit then picking up the pieces seperate?
It's probably cheaper to sell your car and buy one that's already a 5spd. The next cheapest option is probably going to be buying a donor car. From there it's up for debate. Most places that will sell you a conversion are probably going to include some pieces you don't need, and probably won't supply everything you do need, and they'll charge a premium for the convenience. Piecing together a swap may be cheaper, but it'll take longer.
Engine: 3.1 V6
Axle/Gears: STOCK
so i am better off going to a junk yard and stripping the pieces i need from that in order to change it? and thanks
If you can find a donor car in the junkyard, one stop shopping is your best bet. Otherwise it's really easy to end up with half the parts and never get it done.
