Safety switch for clutch.
Old Mar 17, 2010 | 10:51 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
Can anyone tell me where the clutch safety switch is? Its the one you have to press the clutch in to start the car. I need to re-route it to my auto shifter.
Thanks, Chas
Old Mar 18, 2010 | 12:06 AM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Re: Safety switch for clutch.
Here is a pic of a set of 4th gen pedals. Look on the left you can see two wires coming from a black switch. That is the safety switch. Same thing on 3rd gen pedals.
Old Mar 18, 2010 | 12:22 AM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Thanks, Chas
Hello chas0218!!
If you look at the clutch pedal, there should be a black switch that contacts the pedal up near the pivot point!! It's about two inches long by about 1/2 inch thick!!
Old Mar 18, 2010 | 12:24 AM
Hello alloy!!
You beat me to it, and a picture is worth a 1000 words!!
Old Mar 18, 2010 | 08:53 AM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Thanks guys this helps a lot!
Old May 8, 2010 | 05:14 PM
joecool108's Avatar
Car: 91 Vert, 69 SS, 91 Coupe
Engine: V8, V8, V6
Transmission: Auto, Auto, 5 speed
Can anyone give me a diagram or a close up picture of where it goes on a 3rd gen. I have the switch and need to install under the dash, but cant seem to see where or how it mounts.. any help is appreciated.
Old May 8, 2010 | 05:27 PM
juanillox8's Avatar
Car: TOO MANY
Engine: 350 TPI / 350 TBI/6.0L VORTEC
Transmission: T5/AUTO/AUTO
is just like in the pic on the left of the clutch pedal
Old May 8, 2010 | 07:30 PM
joecool108's Avatar
Engine: V8, V8, V6
My pedals are in the car, and the above photo is not close enough to see how it is mounted.
Old May 8, 2010 | 07:55 PM
juanillox8's Avatar
Car: TOO MANY
sorry its hard to get a good pic with the pedals on the car hope it helps
MM2Robinson
Oct 1, 2017 09:16 AM
Veaceonee
Sep 29, 2016 08:15 PM
RacerM
Sep 28, 2015 04:25 PM
Fronzizzle
Sep 8, 2015 12:10 PM
tonys91rs
Sep 2, 2015 07:07 PM
