Gear swap problems
Old Apr 6, 2010 | 02:10 PM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Transmission: 700R4,700R4
Axle/Gears: LSD,LSD
Gear swap problems
i have an 87 rear end and im trying to put 3.73's from on 86 s-10 in it... im trying to put the pinion in from the s10 and i get the nut as tight as i possibly can and i still have slop in it...its a new crush sleeve and i took it back out and it looks as if the crush sleeve didnt even get touched....what is going on??
Old Apr 6, 2010 | 07:50 PM
big gear head's Avatar
Re: Gear swap problems
You aren't using enough torque on the nut. When you get around 300 foot pounds of torque the spacer will start to crush.
Old Apr 7, 2010 | 01:08 PM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Axle/Gears: LSD,LSD
im getting it tight as S**T...it seems like im running out of threads/splines
Old Apr 7, 2010 | 06:49 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Trust me, it takes A LOT of torque to get that bolt tightened down correctly. Do you know when to quit tightening though? Also, did you see what the backlash was on those gears before you took them out of the old rear?
Old Apr 7, 2010 | 07:02 PM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Axle/Gears: LSD,LSD
yes i know when to quit...yes i know what backlash needs to be....i just feel retarded because i went to school for this and apparently its a challenge for me
Old Apr 7, 2010 | 07:05 PM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Axle/Gears: LSD,LSD
and i was tightening it with a jack and a breaker bar...with the yoke held by a socket sitting in the torque arm and i was getting it so tight that i was starting to bend the torque arm...sooo yeahhh...wtf is wrong
Old Apr 7, 2010 | 07:35 PM
built91Z28's Avatar
Without being there I cant say for sure that nothing is wrong, but I have had some that were that tight. I have some 3/8 bolts that I've used to hold the pinion still and they are bent over. Some are just extremely tight. To the point where it requires several hundred pounds of torque to move it.
Old Apr 7, 2010 | 08:41 PM
Where did you get the spacer? You might have an after market spacer that is more ridgid that it needs to be. You might try a GM spacer. These things are real hard to crush. I use a 3/4 inch drive breaker bar with a 3 foot cheater bar.
InfinityShade
Aug 22, 2015 08:00 PM
jharrison5
Aug 19, 2015 05:53 PM
mizz0313
Aug 12, 2015 06:45 AM
hokis
Aug 9, 2015 03:57 PM
