Spider gears...
Old Apr 16, 2010 | 09:45 PM
jj922011's Avatar
Car: 1984 Pontiac Trans Am
Engine: 305cid Carb
Spider gears...
hi,
i bought 3.73:1 gears, heres the specs.
Ring and Pinion Ratio
3.73:1Cover Bolts
10 Ring Gear Bolts
10 Pinion Spline Count
27 Ring Gear Rotation
StandardRing Gear Teeth
41 Pinion Gear Teeth
11 Ring Gear Diameter (in)
7.500 in.Pinion Shaft Diameter (in)
1.438 in.Installation Kit Included
NoQuantity
Sold as a set.Notes
Fits 3.23 and numerically higher carriers.
what size spider gears do i need? please i need your guys help. thanks
Old Apr 16, 2010 | 11:52 PM
toomany's Avatar
Re: Spider gears...
Unless there was a major problem with the ones currently in the car, you should be able to reuse the stock ones. There aren't differnt sizes (actually there might be, with the carrier breaks). Now would be a good time to upgrade to a posi unit.
Old Apr 16, 2010 | 11:58 PM
jj922011's Avatar
Engine: 305cid Carb
Re: Spider gears...
i snapped both of them, so i thought might as well go to a better ratio, what would be the best spider spline size? and it is a posi, i have 4 spider gears, 2 small and to medium sized ones, the 2 small ones are on the top and bottom and the medium ones are the ones that connect to the axle.
Old Apr 17, 2010 | 09:51 AM
AaronIROCZ's Avatar
Moderator/TGO Supporter
Re: Spider gears...
I can only assume you are working with a 7.5" rear end. And if this is the case you can use any side gears from a 7.5" rear end from GM as long as the axle spline count is the same.
Old Apr 17, 2010 | 07:10 PM
jj922011's Avatar
Engine: 305cid Carb
Re: Spider gears...
yes i am working with a 7.5in GM rear end, and so it doesnt matter what spline the spider gears are? or what?
Old Apr 17, 2010 | 07:34 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Spider gears...
it DOES matter what the spline count is, a 26 spline gear wont fit on a 28 spline axle.
if you 84 has a stock axle, its 26 spline
Old Apr 17, 2010 | 08:06 PM
big gear head's Avatar
Re: Spider gears...
The 2 gears on the sides are the axle gears, which have the splines in them, and the 2 gears that are on the cross shaft are the pinion gears. GM changed the sizes of these gears a few times. 28 spline gears will not fit into a case that had 26 spline gears in it. There are a few different gears in the 26 spline size too. You will have to match up another set of gears with the gears that you have.
Old Apr 18, 2010 | 09:40 PM
jj922011's Avatar
Engine: 305cid Carb
Re: Spider gears...
i am replacing all the gears in the carrier, so for a 27 spline gear i need a 27 spline spider gear?
Old Apr 19, 2010 | 07:51 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: Spider gears...
You are confused on the technical names of the parts in the rear diff and there function. Your knowlege shows with questions about spider gears and spline count. Check the terms: side gears, side pinion & spider and the functions in a rear diff assembly....
Old Apr 20, 2010 | 08:17 AM
jj922011's Avatar
Engine: 305cid Carb
Re: Spider gears...
yes i am comfused haha, but with that im mind, where can i find a set of all 4 gears? i already have the ring and pinion, i just cant find the 4 other gears.., if thats makes it a little clearer on what i am trying to say.,
Old Apr 20, 2010 | 09:30 AM
DJP87Z28's Avatar
Re: Spider gears...
You can seach, but I would suggest that you buy a new LIMITED SLIP carrier and that would solve your problem. However: you need to know the spline count of your axle shafts & what gear ratio you now have. You never did state these important facts or give us the year, engine tanny you have (if it is stock)????
Old Apr 20, 2010 | 04:37 PM
Re: Spider gears...
You bought a set of 3.73 gears that fit a 3 series differential. If you are replacing a set of 3.08 to 2.41 gears then you are going to need a complete differential anyway because you have a 2 series differential and you must have a 3 series. If you are replacing 3.23 or 3.42 gears then you have a 3 series differential and you can use it. So what do you have? What is the current gear ratio? How many splines on the axles? This is required information.
F-body driver
Mar 6, 2023 11:44 AM
woody86
Mar 29, 2002 10:16 AM
87 Teach's Pet
Feb 19, 2002 08:45 PM
87 Teach's Pet
Feb 19, 2002 06:16 PM
Jer82Z28
Sep 25, 2000 09:19 PM
