How hard would it be to put a TH350 in a 84 Z?
Old Apr 25, 2010 | 12:03 AM
91camarolover's Avatar
Car: 91 RS, 84 Z28, 85 Iroc-z
Engine: 3.1L, 350 4 bolt, 350 TPI
Transmission: 700R4, 700R4, 700R4
Axle/Gears: 3.23, Unknown, Unknown posi
Well read the title...
Old Apr 25, 2010 | 12:22 AM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: How hard would it be to put a TH350 in a 84 Z?
well that depends on what you consider to be hard. i guess you're replacing a 700r4? you will likely need a different driveshaft, speedo gear, dipstick tube, and place to mount the torque arm.
Old Apr 25, 2010 | 12:30 AM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Whats your definition of hard? I had one in my car but just took it out for my T56 swap.. I started from scratch though. I bought a Hughes TH350, Spohn torque arm/crossmember, Lockar firewall mounted dipstick, Lockar kickdown cable, and Spohn driveshaft. You'll need a convertor too. If you buy everything like I did, you just bolt everything in.
If you use a longtail TH350, I believe you can use a stock driveshaft. If you use the shorttail like I did you will need a new one. You will also need a different crossmember than the stock one. If you currently have a mechanical speedometer then you'll be ok on that.
Old Apr 25, 2010 | 12:36 AM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
if you get a long tail TH 350.. all you will need is the B&M torque arm adapter.. same crossmember & same Poly trans mount..
and the spedo gear will be easy to find to match your gear ratio
Old Aug 24, 2010 | 11:40 PM
91camarosRS's Avatar
Car: 02wrx/88 rs
Engine: 2.0L turbo/nothing yet!
Transmission: 4eat/waiting on a t56
Ookk im doing this research for a friend of mine. I dont mess with th350 s at all so help me. I was told by someone else that you can take the tailhousing off the 700 and bold it onto the th350????
Old Aug 26, 2010 | 01:55 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
exactly what i did last time. bolted right into place
Old Aug 27, 2010 | 05:16 PM
codyhoward89cam's Avatar
Car: 1992 camaro rs
Engine: sbc 305
Transmission: t5
Axle/Gears: 3.08
what car did the long th350 come in and were do i get the speedo gear
Old Aug 29, 2010 | 12:01 AM
Pairof91rss's Avatar
Car: 1991 B4C-1991 RS
Engine: L98 5.7 TPI-LB9 5.0 TB
So can you use the same driveshaft off the 700?
I got a 355 I am gonna throw in my 305 tbi RS, with a turbo 350. Or what would I need to run the 700r4 with a carbed motor?
Old Aug 30, 2010 | 07:43 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
as long as you have the long tail th350, the stock drive shaft will work without modification. when i had done my swap, i lucked out and grabbed my motor and trans from a 78 C10. Not sure if anything had been swapped on it before as i was nowhere near the original owner.
as for the gearing, you should be able to buy those from a GM dealer or summit/jegs. you just need to know what you're going to have for rear end gears and tire size to get the right ones.
Old Sep 24, 2010 | 02:32 PM
Spaceman77's Avatar
Car: Camaro Z28 1986
Engine: 4bolt 350
Transmission: th350
After I changed my th700 to a th350 my speedometer began to jump whats the problem how do i fix it? The speedometerwire i brand new.
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
86White_T/A305
Aug 17, 2015 12:16 AM
squiggy2
Aug 9, 2015 09:30 PM
