Cross shaft pin screw wont fit
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
I just got done installing my no slip and I ran into a problem. I put the cross pin in and ready to slide the screw in and it seems like its too long and it hit the bearing cap. Now i got this screw from the dealer which is PN# 25872305 which he said crossed with PN#14056196 . Can anyone verify that this is the right part number ? If it is would i be ok to grind a little off the top of the hex head so it can slip buy the bearing cap ?
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: Cross shaft pin screw wont fit
dont grind it. rotate the carrier some and it should slip in towards the top or the bottom
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
https://www.thirdgen.org/forums/tran...ing-axles.html
JamesC
Car: 1984 z28
Engine: 355
Car: 1984 z28
Engine: 355
Correct part number for my 85. The following link should provide some useful info for installing the bolt:
JamesC
JamesC
Car: 88 IROC
well then pull the bearing cap back off and slide it in and see if it works or not. Do you have an old one to compare the new one too?
Car: 1984 z28
Engine: 355
They old carrier was thrown out. That bolt broke in it and I didnt feel like screwing with it so I took a cut off wheel to it and hacked it out. I had a new aftermarket carrier so the old one was useless to me.
I measured an old OE cross pin bolt. Overall all, it's two inches. BTW, I ordered mine from the dealership. The bag has the xxx196 number on it. The link above also provides the Napa p/n should that be of any use. Good luck.
JamesC
JamesC
Car: 88 IROC
yeah I always replace them with new ones anyway. Cheap insurance.
If its being that big of a problem, I would just pull the bearing block off and install the pin. But definately be carefull when installing it. If it doesnt want to go, it could very well be the wrong one. Dont force it. Odds are it will probably work, then just put the cap back on, button her up, and take it for a spin.
Hey JamesC, any reason you go to a dealership? Ive always picked up mine from the local Standard's help rack for $2. Just curious.
Car: 1984 z28
Engine: 355
Well i bought 2 of the gm bolts to have an extra on hand. i think i will go to Napa and get one and compare them. I think its more the aftermarket carrier giving me problems more than anything.
Put the bolt in before you put the bearing cap on. This is a comon problem. I always install the bolt before putting the differential in. You don't have to pull the bolt all the way out to remove the shaft. All you have to do is slide it out a little and the shaft will come out. Just remove your bearing cap, put the bolt in and reinstall the cap.
Car: 1984 z28
Engine: 355
Well i got the pin in and GM caked so much locktite on it that it didnt want to thread in. I had to screw the bolt in and back it out about 10 times to compress the locktite. When it was almost seated i just kept screwing it in it was hard but kept going in and then the hex head stripped. So now i have about 2 threads left showing and the head is stripped. How can i get this bolt out with out stripping the hex worse ?
I don't know if you use a 12 point or a 6 point wrench on this bolt, but I always use a 6 point. The head on these bolts rounds off too easy with a 12 point. I bought a special 6 point wrench just for this reason.
Car: 1984 z28
Engine: 355
It was a 12, its all i have. What the best way of getting the bolt out ? I dont to round of the head any more then it is.
Car: 88 IROC
try the 6 point, but be careful. If you feel it start to slip, stop. A small propane torch to slightly heat up the carrier around the bolt hole can help too.
If that dont work, a slightly smaller socket might work if you have rounded it too much for the 6 point to bite.
last resort is to use vise grips.
Car: 1984 z28
Engine: 355
I'm gonna try tonight and see what happens. If nothing else works im just gonna put a wrench on it and tack weld it to the hex head and get it off that way. I figures that i just had the rearend completely rebuilt and the last bolt that goes on is the one that bites me in the @ss.
Car: 1984 z28
Engine: 355
I went to sears and bought a 6 point 5/16 wrench and it worked like a charm. Its all bolted up and ready to brake in. Thanks guys.
Street Lethal
Apr 30, 2019 12:14 PM
1Aauto
Sponsored Vendors
Apr 9, 2018 03:00 PM
ambainb
Apr 25, 2016 09:21 PM
