Governor Question
Old Jul 15, 2010 | 11:00 PM
jamienoel's Avatar
Car: Mystifying 1989 TBI Camaro.
Engine: 1992 350 Truck Engine. TBI
Transmission: 700R4 when it wants to be.
Governor Question
I bought a used governor on eBay (30 day warranty) for $0.99 cents with $5 shipping. Nobody else bid on it and the picture shown did not look like this one, but the question I have is: Does this look right? The metal piece where the boob/bump is seems a little bent in. Is this how it is suppose to be or was it done by someone hitting on the cover to push it in or something?
Here are some pics. You can clearly see where it's bent in.
Old Jul 17, 2010 | 05:35 AM
jamienoel's Avatar
Re: Governor Question
Nobody has seen one?
Old Oct 10, 2010 | 01:52 AM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
I just got done putting the same governor in my trans and yes, that is definitely damaged.
Old Oct 10, 2010 | 02:45 AM
jamienoel's Avatar
I almost put it in today, too....
Old Oct 10, 2010 | 03:17 AM
Car: 1985 Z28
It looks like someone beat the hell out of the governor cap trying to get it back in and smashed it into the governor. That nipple on the end of the governor sits against the inside of that cap.
Old Oct 10, 2010 | 05:19 AM
jamienoel's Avatar
I didn't think it was right, but couldn't find a photo anywhere to compare. The guy I got it from said it was fine.
I imagine straightening it back out would do the trick?
Old Oct 10, 2010 | 08:00 AM
Car: 1985 Z28
You can try, and it will probably end up being fine. Just bear in mind that if it causes the governor to bind, the car will shift erratically if at all.
I might be able to give you a good deal on a corvette governor if you're interested. It was what I pulled out of my transmission.
Old Oct 10, 2010 | 10:02 PM
jamienoel's Avatar
I guess my main concern will be if the gear is chewed up on the old one.
Other than that, do they develop problems?
I only paid a few bucks for it, so if it doesn't work, I'm not out of much. I just want it to shift correctly, but I'm thinking it could be a valve problem with the 3-4 points after it's hot.
It has been driving me insane about how it shifts perfectly until warmed up and then gives me trouble in 4th unless I'm on a pull, even going up a very small grade/hill somewhere.
It will shift right into 4th at 45 then. It will actually sometimes shift at 40 and just below, but once the tranny is hot, it can give me problems at 55 and sometimes even 60 getting back to 4th unless once again I'm on a pull. The pull can also be on flat road if I give it some gas to create a pull.
I also keep wondering if it could be a pressure problem since it usually screws up on level ground once I'm at speed? Just the slightest pull and it shifts to 4th. I know I keep repeating this, but nobody can figure out why. AAMCO even thinks I'm wacko when I describe the problem.
Old Oct 10, 2010 | 10:55 PM
n1ffer's Avatar
Car: 1983 Crossfire Recaro T/A
Engine: 5.0L Crossfire
Transmission: Upgraded 700R4
Axle/Gears: 3:23
Have you adjusted your TV cable to the correct GM process and checked your line pressures to the factory process?
The TV cable being out of adjustment will cause many problems as it controls line pressures to the trans which controls your shifts.
Old Oct 11, 2010 | 12:09 AM
jamienoel's Avatar
I did mess with the TV cable and found that it did not shift correctly unless the full throttle "click" adjustment was done, which put it back to it's original position.
It works fine when cold!
As far as the line pressure, I have no idea. I've never tried anything like that and haven't even looked up the pressure specs.
Does the pressure gauge hook up where the lines go into the radiator? I don't know if AutoZone loans them out.
It's terrible when you don't have the money for anything and can't be without transportation.
It's my only car now because I had to junk the Buick. There is no option of selling this car because my mom gave it to me the night before she died back in 99 and the sentimental value is priceless, so even though I'm about to be living in it, I won't sell it to prevent that from happening.
Old Oct 11, 2010 | 03:05 PM
n1ffer's Avatar
Axle/Gears: 3:23
Jamie - sorry you are in a tough spot. Keep your head up dude, it will work out! It always does!
The line pressures are checked using an engine or trans oil pressure gauge that will go up to 300 psi. There is a small bolt head or plug sticking out of the transmission on the driver side - more toward the front bell housing and about half way up the side of the trans. It points toward the drive door and is parallel with the ground.
I want to say it is a 8mm size or so. You unbolt the plug and thread in a 1/8" NPT connector that has a 90 degree elbow bend and you screw the gauge into the NPT connector.
Here is the chart - you have to make sure you check your trans model number and then follow the steps:
Attached Thumbnails Governor Question-700r4ps1.jpg   Governor Question-trans-model-image.jpg
Old Oct 12, 2010 | 09:46 PM
jamienoel's Avatar
Thanks for the info! I'll have to check and see if my uncle has anything like that. I know he has some kind of gauges, but I have no idea what they are for.
You must be young. My daughter calls me dude sometimes and I don't really look like a dude.
MustangBeater20
Oct 29, 2022 09:20 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
crazynights
Aug 21, 2015 06:53 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
