how do you guys have your wires routed
Old Aug 10, 2010 | 06:21 PM
0pyders's Avatar
Car: 86 Firebird LG4
Axle/Gears: 3.23 limited slip
mine is 700r4
those 2 wires that connect to the transmission. one goes on the tail part and i looked on the driverside part of the trans. but couldn't find anything to plug the other one into, anyone got a picture? and also I want to know where you have your wires ran, I got mine going under the transmission pan but that can't be right because it's such a tight fit to plug in the tail housing plug.
Old Aug 10, 2010 | 06:37 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: how do you guys have your wires routed
My t5 has a few wires that go nowhere, there's 2 connectors and only one connection
Old Aug 10, 2010 | 08:13 PM
Destructimus's Avatar
Car: 1992 Firebird
Transmission: 700R4 with B&M shift kit
Axle/Gears: 3.23 zexel 4th gen
The other ones should be a set of three wires, right? Mine goes to a socket that is on the driver's side of the transmission. You probably can't see it because it it plugs straight down into a socket that is facing upwards on the transmission. It should route over top of the transmission, or more likely come directly from a cluster of wires on the driver side. Get on your back and feel around the area directly above the trans oil pan on the driver's side. It's a square socket and your plug should only fit in one way based on the clip in the plug. If you can't find it, I will try and send a pic because I actually have to mess with the same thing today or tomorrow.
Old Aug 10, 2010 | 08:22 PM
0pyders's Avatar
yeah I know it's somewhere up there but i couldn't get it plugged. do you think you could also get me a picture of how your wires are routed from the harness to the transmission? It would really help me a lot .
Old Aug 11, 2010 | 04:43 PM
0pyders's Avatar
found where both plugs go but still need to know how the wires should be routed from the passenger side engine bay to the driver side plugs. are the supposed to go over the transmission instead of under? i cannot get enough length on my wires to plug them in.
Old Aug 11, 2010 | 06:11 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
should go over the tranny
Old Aug 11, 2010 | 08:05 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Put em over the top but don't pinch them, if you're having a lot of trouble tho and you're good at soldering id say just lengthen the wires and use some good heat shrink on the joints, but not too much obviously cuz you don't wanna drag the wires on the ground if you go under
Old Aug 12, 2010 | 04:14 PM
0pyders's Avatar
got em' both plugged, thanks guys.
Infested
May 22, 2018 11:56 PM
Street Lethal
Aug 14, 2015 08:25 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
mx127
Aug 10, 2015 08:13 AM
