I need help putting this bracket on please I beg you
Old Oct 3, 2010 | 05:55 PM
0pyders's Avatar
Car: 86 Firebird LG4
Axle/Gears: 3.23 limited slip
700-r4
and I need to know how to install the bracket to the shifter cable Any one got any pictures of theirs they can show me? I've been attacking it for the past half hour but it never really locks in place, I can move it easily. When I tried shifting it in the car to see if I put it in right, it went from park to drive easily but shifting but from drive to park the cable just slides and doesn't really click. Please help me its really pissing me off. Thanks.
Old Oct 3, 2010 | 07:43 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: I need help putting this bracket on please I beg you
The tangs on the cable don't lock in to the bracket?
Old Oct 3, 2010 | 08:09 PM
0pyders's Avatar
I'm sure they do. What I mean is that I can't get the cable shoved up far enough for them to even lock. I tried all Kinds of shoving, twisting,etc.
Is it supposed to be this hard? I'm thinking of just taking the cable out of the car with the bracket and just mess with it in my house because I get headaches doing that with my head on the concrete floor after a while haha.
Old Oct 3, 2010 | 08:27 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
This is the transmission end of the cable? Stock cable or aftermarket?
Old Oct 3, 2010 | 08:44 PM
0pyders's Avatar
its the transmission end. Stock cable.
EDIT: here we go, found a picture. I need to make this happen: Name:  fdsfds.jpg
Old Oct 3, 2010 | 09:00 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
are you asking what to do with the part circled in red? If so it uses the transmission pan bolts to hold it in place.
Old Oct 3, 2010 | 09:05 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
Are you 110% sure its the factory cable?
I went through 2 aftermarket cables myself before I bought a used GM cable.
Old Oct 3, 2010 | 10:35 PM
0pyders's Avatar
No, I'm not completely sure, it's was there before I bought it. I'm gonna mess with this tomorrow and post a solution if i get one.
Old Oct 3, 2010 | 10:42 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Aftermarket cables use a poor-quality plastic casting, and the tanks often need a little trimming with a knife or file to shorten the tangs so they'll open when the cable is bottomed out on the bracket. Even still, you might find that they don't want to "open" wide enough to securely hold the cable in place.
Old Oct 3, 2010 | 10:44 PM
Tobias05's Avatar
exactly this. and they'll pop out on you at the worst possible time. like when you're manually winding through the gears on the highway on-ramp, for instance.
Old Oct 4, 2010 | 01:24 AM
0pyders's Avatar
Well the thing is that it fit before I took it out of the bracket so I think I have the right one. Probably just me not doing it right.
Old Oct 4, 2010 | 01:34 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Wrap a thick cable tie around it underneath the tangs to space them out and it'll hold securely.
Or buy a GM cable and not have to worry about it.
Old Oct 4, 2010 | 11:40 AM
0pyders's Avatar
just to make sure. Do you guys see anything bad/broken about this cable?
Old Oct 4, 2010 | 07:47 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yes, replace it.
Old Oct 4, 2010 | 11:11 PM
0pyders's Avatar
Ok. Thank you.
Would this look ok? http://cgi.ebay.com/ebaymotors/89-TR...Q5fAccessories
Old Oct 4, 2010 | 11:29 PM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
It's broke, missing a tang...
Old Oct 7, 2010 | 11:52 AM
Tobias05's Avatar
This.
1992 Trans Am
May 10, 2023 07:19 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
evilstuie
Apr 14, 2016 08:52 PM
Dialed_In
Aug 20, 2015 01:45 PM
