Is there an auto shifter that fits in manual console?
Old Oct 27, 2010 | 10:44 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I have a manual trans car with a 4th gen Firebird center console swap. I am going to an auto (probably 4L60E). Is there an auto trans shifter out there that looks like a manual shifter and will fit in the manual shifter hole? I'm thinking this will have to be some type of tap shifter rather than a shifter that moves linearly down the gates.
Old Oct 27, 2010 | 10:59 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Is there an auto shifter that fits in manual console?
Automatic shifters bolt to the floor, so no matter what you put in you're going to have to fill the hole.
Old Oct 27, 2010 | 11:20 PM
Stephen's Avatar
Car: 87 GTA
Pop your auto shifter up through the manual trannies boot. It'll still look Manual, but work like an Auto.
That is how my 87 is STOCK. 700R4 tranny & a manual looking boot, just with a slider indicator beside the boot. The indicator doesn't work anymore, so I count count the clicks. 1= Reverse, 2=Neutral, 3=Overdrive, etc. Has been that way since I got the car & is 2nd nature to me.
Old Oct 27, 2010 | 11:38 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Thanks, master of the obvious.
I don't have an auto console. I have a manual console. I found exactly what I was looking for. Check out the posts by TJ. That is freaking slick!
http://www.ls1tech.com/forums/automa...stalled-3.html
Old Oct 27, 2010 | 11:50 PM
Stephen's Avatar
Car: 87 GTA
Originally Posted by QwkTrip
...I don't have an auto console. I have a manual console.....
You obviously misread my post.
I KNEW you had a Manual console. Re-read.....
I SAID.....
Put the AUTO shifter up through the MANUAL boot. That is how my STOCK setup is. Auto tranny with a Manual style boot.
Which is basically what TJs post shows....
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Edit: Actually, I didn't misread anything.
1. You're example was a manual boot on an auto console.
2. The real question is what shifter will fit. You can't just stuff any old shifter in there and expect it to work in the confines of the M6 hole. It has to be a ratchet shifter.
I appreciate your first reply, but the second was out of line. These attitudes is exactly why I rarely visit this site any more. I found the answer to my question and posted it here so others can benefit if they run a site search.
Old Oct 28, 2010 | 12:23 AM
Stephen's Avatar
Car: 87 GTA
You are STILL misunderstanding....My example was NOT a Manual boot on an AUTO console. You have a reading disorder? I'm sorry to hear that....
Mine console is 100% BONE STOCK...BONE STOCK...BONE STOCK! Instead of a slider, it uses a manual style boot.
Old Oct 28, 2010 | 12:31 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Can you post a picture? I'd like to see what you did and how it turned out.
Old Oct 28, 2010 | 12:49 AM
Stephen's Avatar
Car: 87 GTA
I did nothing. GM did it all back in 1987......
Old Oct 28, 2010 | 01:06 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
This is getting pretty humorous because our minds are seriously not connecting. I don't want to keep struggling with you and I found what I needed. Have a good evening.
Old Oct 28, 2010 | 01:34 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
https://www.thirdgen.org/forums/inte...ro-center.html
very common for guys to put 4th gen manual consoles in automatic cars. Did it myself. Much less work then trying to put an auto console in. any stock or stock replacement shifter will fit.
Old Oct 28, 2010 | 05:37 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Good link. Thanks!
1992 Trans Am
May 10, 2023 07:19 PM
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
colton_carlson
Mar 8, 2019 12:21 PM
TheJoeY88
Aug 13, 2015 06:51 PM
