B&M Shifter install pics?
Old Nov 14, 2010 | 08:59 PM
chevydrvr's Avatar
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
I have a B&M shifter in my camaro that the previous owner installed,but he never installed the reverse light switch. According to the install directions from teh B&M website, it comes with one.
I'm just asking for pics of somebody's shifter installed so I can see what I need to do...thanks!
Old Nov 18, 2010 | 09:03 PM
vortec350s10's Avatar
Car: '88 Iroc
Engine: Single turbo Vortec 5.7, Megasquirt
Transmission: Probuilt 700r4 3000 stall Vigilante
Axle/Gears: Moser 9" 3.25 w/True Trac
Re: B&M Shifter install pics?
You can see the two switches there on the left side of the shifter. Nuetral safety switch, and reverse light switch.
Old Nov 18, 2010 | 09:11 PM
chevydrvr's Avatar
Yup, I see it now. It previous owner just the left the switches in the console. One looks like it was used at one point but then cut out. Thanks!
Should the sifter have a little play in it? As in it can forward/backward a little? Not the whole thing just the handle itself?
Old Nov 18, 2010 | 09:26 PM
Car: '88 Iroc
Yeah mine does. One thing you may wanna think of doing if you care is reinforcing it for side to side flex. Mine flexed a lot and when taking hard corners using it as a handle for my right hand to hold myself up on corners, it flexed enough to hit the reverse light switch. I added some gussets and stiffened up the floor as well. It helped out a lot.
Old Nov 18, 2010 | 09:29 PM
chevydrvr's Avatar
Good idea, i'll keep it in mind!
Old Nov 18, 2010 | 10:14 PM
92Firebug's Avatar
Car: 1992 Pontiac Firebird Base
Engine: 305 TBI
Transmission: 700r4, B&M shifter & shift kit inst
Axle/Gears: 3:23....10 bolt
MAN I AM SUBSCRIBING! anyways i am installing mine when i dont work maybe next monday its gonna be awesome but there are a lot of parts so im really intimidated
Old Nov 18, 2010 | 10:16 PM
chevydrvr's Avatar
Goodluck! Let us know how it goes.
Old Nov 18, 2010 | 10:40 PM
MSRed91Camaro's Avatar
Car: I have a 91 Camaro RS
Engine: 383 stroker
Transmission: Stock automatic 700r4
Axle/Gears: I have 3.73 Gears with a Eaton posi
subscribed, I have heard that you can bypass the neutral safety switch....anybody know Im not saying that its a great Idea to do it cause your car will start in any gear but I dont think my uses B&M shifter came with one.. Id just to like my options
Old Nov 20, 2010 | 12:13 AM
92Firebug's Avatar
Engine: 305 TBI
will do
camaro11j
Sep 19, 2018 08:49 AM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
NBrehm
Aug 25, 2015 11:49 PM
mustangman65_79
Aug 13, 2015 07:36 AM
sonu1975
Aug 11, 2015 08:38 AM
