shifter replacment!!
Old Jan 27, 2011 | 03:30 PM
Iroc-Dennis's Avatar
Car: camaro iroc-z
Engine: 355 L98 Corvette engine
Axle/Gears: 3.27 9 bolt borg warner
hey all,
i going to swap my T5 out and will take a th700r4 in the camaro.
i only have to know how i must build on the shifter in the console!
i have a manual shifter now so there is a big hole in the console.
maybe i take a B&M shifter or the original shifter.
what would be the best option for me because that big hole down there?
i have not the original brackets on that location like you all that have original a automatic transmision.
i have search on some universal shifters from B&M but don`t know what to do.
who could help me? it would be nice if you have some nice pics of a swap from manual to automatic.
d.vanmierle@chello.nl
thanks dennis
Old Jan 28, 2011 | 03:51 AM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Re: shifter replacment!!
I think most go from auto to manual instead.
The shifter should not be too bad. Weld a plate or even screws and sealant to fill the hole. All you will need is a small round hole for an automatics shifter cable.
As for what shifter, the automatics have some brackets welded to the floor where the shifter mounts to. You may be able to mount a shifter on blocks to put it at the right height.
Also what are you going to do with your console? Put an automatics top plate on there?
If you do go with a B&M or Hurst shifter you may need the kind that ratchets in gears from 4 to 3,2 and 1. The stock automatic shifter plate is not long enough for the throw of an aftermarket shifter that does not ratchet.
Old Jan 29, 2011 | 06:33 AM
Car: camaro iroc-z
thanks for your good explain about my shifter.
i know i must make a hole for the cable,and must fix the big hole thats for now.
i still don`t know what shifter i take.i read some bad info about the B&M shifter.some say it hard to shift in some gears.
the original shifter is a lot cheaper and look good also.
my plan was to change the shifterplate only on the top of the console.
do you know some people who did the same swap like me?
Dennis
Old Jan 29, 2011 | 04:08 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
I had a B&M in my 84 Z28 and I will never go with B&M again. I was hard to shift. So hard that my brother ripped the handle off) Also the B&M made to fit in the 3rd gen console would hit the plate and stripped out the screw holes. Every time I would click down into 3,2, or 1 it would pop up from the console.
I'll try to find out what Hurst I used in my mom'e S10 but the Hurst works great. Its a simpler design that does the exact same thing as the B&M. Shifts real smooth and easy. The only difference is this Hurst you lift and push on the shifter for its lock out. THe B&M had a lever. I'll still go with Hurst from now on.
Nothing wrong with the original shifters. You know they will fit and the cable is short. The aftermarket shifters have a long cable that needs to be looped around.
Old Feb 2, 2011 | 03:55 PM
Car: camaro iroc-z
okey thanks for the explain about that B&M shifter.
i think i go original !!! haha
i only must make a bracket on my tunnel because the original automatic cars hase a bracket there to bolt up the shifter.
i don`t have one.
dennis
Old Feb 2, 2011 | 04:36 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
i don`t have one.
dennis
That is just a small bump in the road to get over.
Depending on how you want to bolt it down, you could easily make some short spacer to fit between the shifter and the floor.
Old Feb 3, 2011 | 11:01 AM
Car: camaro iroc-z
do you now how high the spacer must be to mach with the console??
i was looking for some pics but that is hard to find.
dennis
Old Feb 3, 2011 | 03:41 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
dennis
Never bothered to measure.
But if I take my shifter plate off, or when you get the shifter which ever comes first, I'll measure and take a pic if I can.
Old May 9, 2011 | 04:28 PM
Car: camaro iroc-z
did you have a picture for me??
the swap is almost on the begining!!
dennis
BewleyBizzIROC
Feb 3, 2020 09:52 AM
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
NBrehm
Aug 25, 2015 11:49 PM
Dialed_In
Aug 20, 2015 01:45 PM
Fronzizzle
Aug 9, 2015 01:15 PM
