trying to find stall speed
Old Jul 16, 2011 | 12:11 AM
affliction1's Avatar
Car: 89 chevy camaro rs
my camaro is a 305,and i was told by po that it had a 3400 stall,but when i do stall test if i get to about 3k the tires break and burn some rubber.also have some rotating noise coming from the tqconverter area,it happens in all gears vary noisy at idle quiet at rpm over 1500,shifts perfectly threw all gears ,not noisy while crusing only at idle until i hit the gas
Old Jul 16, 2011 | 11:35 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: trying to find stall speed
The only way to find the true stall of a converter is with a transbrake. The same converter behind different engines will have a different stall speed. The "rated" stall speed is only an estimate.
At WOT when it shifts, what rpm does it drop back to? Should be the same in all gears. A replay tach really helps to watch it.
Old Jul 16, 2011 | 03:11 PM
Guest
Guest
Posts: n/a
Also, there are 2 common ratings for stall. Flash, and footbrake. Your footbrake is obviously around 3000. To find your flash stall, go somewhere and stop on a deserted road. Keep your left foot out of the picture. Take your right foot off the brake pedal, then immediately floor the go pedal while watching the tach.
Whatever you have, it's more than most mild 305s need. It may be a lot of fun, or it may be annoying. If it's annoying, try a bigger number axle ratio.
But with a 3000 footbrake stall, it's ready for a really wild cam.
Old Jul 16, 2011 | 09:24 PM
torque_is_good's Avatar
do you really have an RS? Is it still the TBI engine? If so, your tach is broken.....I'm serious and the PO was clueless
Old Jul 17, 2011 | 12:07 AM
lol its a carb converted yes its a 305 just vary well breathing edlebrock headers vortec intake/heads edelbrock 550 carb,pro comp dist,no ac no computer no heat no dash pad lol bought 90-92 pad on accident from jy and its a aftermarket tach,belive me i know the tach works.
also what abt the noise/think its from the tq converter?
Old Jul 18, 2011 | 12:06 PM
bump
Old Jul 18, 2011 | 07:51 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Try a different converter to see if the noise goes away. Look for a cracked flexplate. We can't diagnose a noise through the forum without you checking things.
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
SavingPvtEric
Aug 24, 2015 08:39 AM
Bryan F
Aug 18, 2015 02:28 PM
TreDeClaw
Aug 14, 2015 06:58 PM
