CF or Aluminum drive shaft suppliers?
Car: NissanGTS-T, Nissan350z, 89IROC
Engine: 350ci
Transmission: TH700 4 speed automatic
Axle/Gears: 2.77
Gidday,
I was wondering who you would recommend for Carbon Fibre or Aluminum Drive Shafts to suit '89' 350 Iroc?
I have been searching for hours and have only found an Aluminum shaft from 'The DriveShaft Shop' for $400......
Any others out there??
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
Re: CF or Aluminum drive shaft suppliers?
All third + fourth gen cars share the same tail shaft size.
An aluminium tail shaft was an option on third gens (RPO code JG1).
Second hand ones cost about $100 and do the job and there are plenty around.
Engine: 350ci
Axle/Gears: 2.77
Cheers! That sounds like the way to go. I did read up on the rare 1LE's having had them which got me thinking about getting something the same.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Transmission: T700
Apparently a of the V6cars had aluminium drive shafts, but few V6s made their way to Australia.
Car: check
Engine: check
Transmission: check
Transmission: T700
All Camaros wre imported privately into Australia, none by GM as far as I know.
Probably a zero chance of getting that type of part locally from GM.
Just buy one from the USA off of eBay for $120 bucks. Get it sent to a shipping agent who will add it to a container. You'd get it a few weeks later and the shipping agent will probably charge $50 for freight and handling.
I use East Coast Mustang as my shipping agent, who are in Melbourne. Peter Smith at East Coast Mustang is a great guy. There should be others in Brisbane.
Car: `86 SS / `87 SS
I know someone in AU who exports and probably imports as well if you need a reference.
There are a few ways of going about this and not spending the $400. I bought a used aftermarket alum. shaft for very reasonable on eBay. If you wait long enough and find auctions ending at odd times, you can do okay.
While lengths aren't a universal factor, u-joints tend to be. So you may find one in your country that could be used with an adapter u-joint. For example, the Ford full size saloons here used as squad and taxi are donating their alum. drivelines to GM car enthusiasts.
Also, maybe you can find a used Holden unit that's perfect but for length. Driveline shoppes have a minimum shortening amount they're able to shorten; some will avoid it heavily so they can sell you a whole new unit. I'd at least find out criteria for shortening (such as consistend o.d. rather than varied) and range of costs to shorten a good used unit.
Because $400 is the going rate on alum. new ones, Start figuring out the hours you could spend self-educating on u-joints, surfing the internet and how easy it is for that $400 to make a lot of sense if you can just work some overtime.
G'luck.
G'luck.
Engine: 350ci
Axle/Gears: 2.77
Thank you all for the info,....
I think I will try & find a second hand unit that will fit.
I have also been searching for Carbon Fiber accessories and Titanium exhausts but have come up short for the F-Body's. (only 2 days of searching)
Any ideas there?
Any ideas there?
Transmission: T700
Paying $200 for an aluminium drive shaft is a reasonable upgrade, but going overboard on carbon fibre or titanium is a waste.
It's hard to get F-Body parts and bits in Australia. Much cheaper and better options if you import them.
Maybe start by putting on some headers and sub-frame connectors.
Engine: 350ci
Axle/Gears: 2.77
All depends how deep your pockets are I guess and the look or sound your after.
I'm aware of header, runners, rockers etc etc............ it's the parts I can't seem to find I'm interested in.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
