Installed a TransGo SK700jr
Old Jan 2, 2012 | 06:18 PM
cerberus's Avatar
Car: 1985 IROC
Here is the thread to my local thirdgen club I belong to.
http://www.nttga.net/forums/showthre...read-with-pics!
Old Jan 8, 2012 | 02:20 PM
cerberus's Avatar
Car: 1985 IROC
Re: Installed a TransGo SK700jr
Found my major issue.
If you ever have shifting issue on a known good tranny check TV cable then Governor before EVER going into VB or shift kits.
By scotiapilot at 2012-01-08
Old Jan 8, 2012 | 10:03 PM
c4ta's Avatar
Car: 89' GTA,98' z28
Engine: 350tpi/ls1/ls6
Transmission: 700r4/4L60e
Axle/Gears: BW 3.27/3.42
what type of shifting problems were you experiencing?
Old Jan 8, 2012 | 10:16 PM
cerberus's Avatar
Car: 1985 IROC
I had a stuck tv shuttle valve. My shuttle valve had a nice ring cut in the aluminum sleeve so it would hang up. After installing the SK700Jr I replace the Valve Body also for one without the aluminum sleeve.
Note the install instructions? Mine was one of the 700 that had the aluminum sleeve in it. Apprently it was common for the aluminum sleeve to get a groove cut in it because of the side forces it takes from fluid flow.
Even after installing the the new VB I still had shift up problems, I had only 1st and reverse.
The moral of the story is to make sure you check TV, then governor. if your 700 has the rear TV sleeve look for a VB that has NO aluminum sleeve. Ill take photos of the ringed sleeve later.
By Scotiapilot at 2011-12-31
Old Jan 11, 2012 | 01:10 AM
LittleBlueZ28's Avatar
Car: 91 Z28
Engine: 350 5.7
I recently installed this kit, and had decent results it shifts firmer but not quite as firm as id like, however the spacer that goes in the spring (item "c" in the photo above) was not in my kit nor was it in my vb to start with so I proceeded without it. I'm thinking this is the key to the firmness I thought it should have. What material was it made from, don't suppose you have a measurement of its length so I can fabricate one myself? Any ideas guys?
Old Jan 14, 2012 | 11:14 AM
Pro Built Automatics's Avatar
Item "C" that goes in the Red spring is to make sure the valve moves when WOT is applied. The vast majority of times the valve will move without this, but this is just in case. It only takes a couple of times of this valve not to move and you can finish the off the transmission. For firmer shifts and quicker downshifts, give me your email, and I can email the modified instructions to you. Larger boost valves and the Corvette servo are needed here for better durability at WOT.
Old Jan 14, 2012 | 12:09 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
What kind of shift issue did you have?
Old Jan 14, 2012 | 10:37 PM
Which shift is this happening on?
Old Jan 14, 2012 | 10:41 PM
ninetyone's Avatar
Axle/Gears: 3:42
Old Jan 14, 2012 | 10:52 PM
Then the drum and band are going away for the 1-2 WOT not to work here. You will need the larger boost valves and the Corvette servo installed at a minimum when you tear down the transmission and you should upgrade the 3-4 clutch pack. Everything else will need to be inspected when torn down to see if anything else needs to be replaced if it has low miles, otherwise a complete rebuild is in order.
Old Jan 14, 2012 | 10:55 PM
ninetyone's Avatar
Axle/Gears: 3:42
ok
Old Jan 15, 2012 | 12:32 AM
If you don't already have the Corvette servo and the larger boost valves, this might help a lot. Worse case scenario, is you have these parts when you go through the unit.
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
gixxer92
Sep 1, 2015 04:32 PM
crazynights
Aug 21, 2015 06:53 AM
