Need help Identifying Ford 9" rear
Old Jan 10, 2012 | 02:10 PM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
I found what I hope is a great deal on a Ford 9" on craigslist. I already bought it, and from spinning the axle have determined it is a 4.10 ratio. It was sold to me as having 3.70's..... oh well.
http://s292.photobucket.com/albums/m...0Ford%209inch/
It supposedly came from an 86 camaro and had the early 80's GM cast iron brakes on it. The guy stated it was a Currie rear, but the torque arm mount doesn't look like any on their website.
Just wondered if anyone can ID it from my crappy cell pics....
I have it at my buddies shop, letting them go through it and make sure its not a total waste of money. I'm sure with what I paid for it, It will be fine.
thanks!
-jason
Old Jan 10, 2012 | 05:21 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Need help Identifying Ford 9" rear
Could be a currie housing, but the mount is odd. It could be an old style TA mount from them.
Old Jan 10, 2012 | 06:09 PM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
well I emailed them to see what they say......
a member on another forum thought it might be a custom rear..... wanna figure out the mystery of it before I sink too much into it
Old Jan 13, 2012 | 12:18 AM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
dont look like a Currie to me. (a few things to look for) ya never know.
if it was from Currie. it would be have a small tag on the back. held on by 2 rivets. with there Logo. and stamped with a part# on the top of the unit.
also there TA Mt starts off with Tubes welded to the Housing.
when i orderd my Currie. it was cheaper to go without the TA.
I dont used it on My car.
wipe the top of the housing off clean. look for the Part #
this is stamped on By Currie. if it's made by them
Old Jan 13, 2012 | 07:15 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
That looks like a junkyard diff with third gen mounts welded on and a home made torque arm mount. Installing the mount with those small bolts is very weak. I wouldn't trust it. I doubt any aftermarket seller would have installed a mount like that.
Old Jan 13, 2012 | 08:44 AM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
yep, seems to be the direction I am leaning towards as well
shame the tq arm mount seems to be the weak link of it. I'd really like to run it.
Old Jan 13, 2012 | 02:07 PM
you can have any good shop weld the Tubes the the housing.
THEY WILL SELL THEM TO YOU. or you can make a set.
the set up is easy..
looking at your pics. somebody took the time to use fresh spring pads and did a nice job.
Old Jan 13, 2012 | 02:49 PM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
Well I have found the tq arm mount for $150, but that might not be in the budget right now..... I'll have it gone thru and regeared and run it as is on street tires until I get the money for the bracket.....
sad part about that tq arm mount is it has so much clearance... nothign to hit the floor board.
I wonder if it went all the way around the 3rd member if that would make it stronger???
i am not a fabricator though, so its prolly best that I don't try to reinvent the wheel at this point
thanks
budofbama31313
Aftermarket Product Review
Sep 16, 2015 12:29 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Redwhisper
Aug 26, 2015 05:02 PM
Linson
Aug 21, 2015 02:12 PM
Street Lethal
Aug 14, 2015 08:25 PM
