'85 IROC 1-2 shift.
Old Mar 18, 2012 | 12:59 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
'85 IROC 1-2 shift.
I recently purchased and '85 IROC. LB9/700R4/3.42 non-posi. It came with some muds and snow Yokohamas which are very traction limited.
Anyways, at full throttle, the 1-2 shift usually exceeds 6000 rpm, with the sensation that the engine is freewheeling for a second, almost as if there is some slippage. Now, the Yokohamas have no traction, (in fact, don't even squeal), so I'm wondering if I'm experiencing tire spin at that moment. I also get that "freewheeling/slipping" sensation on very agressive downshifts.
BTW, I've adjusted the TV cable in the normal manner.
Any thoughts?
Old Mar 18, 2012 | 01:15 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
Re: '85 IROC 1-2 shift.
if it is factory, the tv cable could very well be stretched making "normal" adjustment just about impossible. may need to make little adjustments to get it set correctly. i usually use the lever on the side of the throttle body to set mine instead of using the gas pedal.
Old Mar 18, 2012 | 02:12 PM
chazman's Avatar
Axle/Gears: BW 3.45
Well, definitely not tire spin. Now it does at even light throttle. It's like it doesn't want to upshift.
Old Mar 18, 2012 | 03:10 PM
chazman's Avatar
Axle/Gears: BW 3.45
Thinking it's a worn plastic gear on my governor?????
Old Mar 18, 2012 | 08:20 PM
cerberus's Avatar
Car: 1985 IROC
Yes
Old Apr 9, 2012 | 08:39 PM
aco2451's Avatar
Car: 92 Camaro RS T-Top
Engine: 305 TBI
Transmission: Automatic 700R4
Did you find a solution to this problem, i have a 92 rs that I'm gonna experiencing this with... if i put my foot in it it wont shift to 2ndsecond till 5500 -6000 and i have let off the pedal... but when i start out slow then it will shift at 3500-4000.. but also when I'm gonna at highway speed 70 or so it wont stay in 4ththe it will constantly downshift at the slight let off of the pedal... i took it to a tranny shop and they told me it needs rebuilt... is there anything i can try to help improve my current tranny
Old Apr 9, 2012 | 09:54 PM
chazman's Avatar
Axle/Gears: BW 3.45
Honestly, I've been really busy and haven't had time to look into it. Yours sounds like it's doing the same though.
But generally speaking, my first hand experience is, that no matter what tranny problem you have, 99% of the trans shops you go to, will say you need a rebuild.
Based on Cerberus's experience with his car, I think it's the governor gear.
Old Apr 10, 2012 | 12:37 PM
aco2451's Avatar
Engine: 305 TBI
Yea, I figure that the tranny shop would say that but I guess if they have to open it up they might as well do a rebuild, I just don't see how they justify charging $1200-1400 for it when the rebuild kit is $150.00.
How hard is the governor gear to replace? I can work on the cars but I usually try to stay away from the transmission unless it's changing the tail shaft seal.
I did find a guy that would sell me a 700r4 from a 91 2wd pickup with 91k miles that he hit a deer with the truck for $150.00 but I'm not 100% sure that would work.
thanks for your response. I usually can't get anyone to respond to any of my posts so I have to end up figuring it out myself
Old Apr 10, 2012 | 01:02 PM
chazman's Avatar
Axle/Gears: BW 3.45
cerberus has a good write up on it. http://www.nttga.net/forums/showthre...read-with-pics
Old Apr 10, 2012 | 11:55 PM
85Irocket's Avatar
Car: 85 Iroc
Engine: Don't have one yet.
Transmission: T-5 non wc
Axle/Gears: Disc brake 10 bolt with 373 gears
I had an 87 iroc with the same problem. I had a broken accumulator spring. Fortunatly that spring was taken out while installing a shift kit.
Old May 14, 2012 | 05:40 PM
chazman's Avatar
Axle/Gears: BW 3.45
Update: Trans is getting rebuilt. Pan was full of clutch material and other bits. My low miles "creampuff" has apparently seen some hard use and lots of high RPM, full throttle, manual shifting.
Old May 16, 2012 | 10:27 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
sensation that the engine is freewheeling for a second, almost as if there is some slippage. I also get that "freewheeling/slipping" sensation on very agressive downshifts.
First, seems like a broken 1-2 accumulator spring. Very common. But second, this points toward slippage instead.
Old May 16, 2012 | 10:30 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Would work just fine if you just swap the tailhousings and shifter brackets. May need to swap TV cables also.
mdtoren
Aug 23, 2015 12:52 PM
crazynights
Aug 21, 2015 06:53 AM
mdtoren
Aug 16, 2015 05:45 PM
dhonda200
Aug 11, 2015 11:50 PM
mustangman65_79
Aug 11, 2015 03:17 PM
