Torque converter leaking?
Old Mar 29, 2012 | 03:05 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Iv had a transmission leak ever since iv got my car and now I think I have it filed down. Iv replaced my pan gasket and filter, my transmission full tube seal replaced and both my lines replaced with new but apon taking my car out of the garage today I noticed I had a small puddle of transmission fluid on the ground. Well I climbed under my car and I noticed a small drip coming from my dust cover. So it appears my torque converter is leaking? What all is in there that could leak?
Old Mar 29, 2012 | 03:25 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Torque converter leaking?
Not the converter itself, but the front seal.
Old Mar 29, 2012 | 03:56 PM
Engine: L31 350
Are those prone to leaking? How bad is it to replace?
Old Mar 29, 2012 | 04:03 PM
Engine: L31 350
I'm not finding a front seal?
Old Mar 29, 2012 | 07:33 PM
GeeJenn91RSV8's Avatar
Car: 1991 Camaro RS
Transmission: 700 R4
Your transmission front seal is leaking. I just changed mine last weekend. The transmission will have to be removed to change the seal.
Old Mar 29, 2012 | 09:19 PM
Engine: L31 350
how long can i drive it like this?
Old Apr 2, 2012 | 08:08 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
I wish that was true.
Odds are it is the seal, but it could be the converter.
Old Apr 2, 2012 | 08:13 AM
Engine: L31 350
How long can I drive with it leaking?
Old Apr 2, 2012 | 08:16 AM
3rdgenmaro's Avatar
Car: 88 IROC
If it is a small leak it wont be a problem. For now. It will get worse.
You had better keep an eye on the fluid level and how much it leaks. It could start to pour and will usually do it at the worst time.
Old Apr 2, 2012 | 08:18 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Till it runs out of fluid and quits.
Keep it checked until you can get it fixed.
Its maybe a 5$ part and a few hrs of your time.
Old Apr 2, 2012 | 08:57 AM
Engine: L31 350
Well the reason I ask is because I have a 3 hour trip to another state coming up soon and it's another 3 hours to get back
Old Apr 2, 2012 | 12:18 PM
3rdgenmaro's Avatar
Car: 88 IROC
It is something nobody can tell you. Could go as soon as you start it the next time. Might go ten years. Use your own judgement.
If it was mine, if it was leaking enough to make me ask on here if it was okay or not, then I would probably replace it. 1.5 hrs to drop trans, 15 minute install, 1.5 hrs to put trans back. Could be more or less depending on how good you are at it.
Old Apr 2, 2012 | 01:01 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I did buy a torque converter that had a leak were the hub was welded. With it removed, I seal it off and added compressed air. It had a small crack/pinhole in one of the welds. In your case it is probably the front seal, but it is possible.
Old Apr 2, 2012 | 04:31 PM
Engine: L31 350
I'm went and bought the new seal today and I'm going to surf the classifieds for another TC and just replace them both
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
deracer
Apr 11, 2016 12:04 AM
xxx3man`
Sep 23, 2015 10:37 PM
gwade12
Aug 8, 2015 08:17 AM
