Car slams into gear
Old 03-30-2012, 03:54 AM
Slow87's Avatar
Car: 87 Camaro Lt
Axle/Gears: 4th gen 3:42, posi, disc
Car slams into gear
I have a 87 camaro with a lg4 on it, auto tranny 150k. In the morning when I put it into reverse or drive it slams into gear, so hard in fact in does a mini burnout (tire marks all over the drive way). I read the other post on this discussion, just had a few questions.
From what I have read... Things to checkout, tranny mount, rearend gear play, u joints, and tranny fluid.
I've experience a broken tranny mount before and I don't feel this is my problem. still replacing it though.
No clue how to check the rear end, I will have to take it to a shop for that.
My tranny fluid is brand new, though it seems to be way past full. Could this be causing my problem? It is more gentle after the car warms up. Not sure if its from tranny fluid thinning out or the idle dropping.
What are your opinions? Any thing else I should check before I take it to a shop?
Old 03-30-2012, 10:05 AM
ATCFLYBOY02's Avatar
Car: 1988 Iroc-Z
Engine: 350 TPI; Stock internals
Transmission: 700r4; TCI-CPVB; BW Hi-Frition
Axle/Gears: 4th gen 7.5 w/ 3:42 gear
Re: Car slams into gear
Mine does the same thing... What RPM is the car at when putting it into gear? Mine will do it if its at like 1500 or so but not so much when its below 1k
Old 03-30-2012, 02:29 PM
Slow87's Avatar
Car: 87 Camaro Lt
I have the lt model so no tach. I have no clue. I think in open loop im around 1200 rpms.
Old 03-30-2012, 02:43 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Early 700R4s have no accumulators to soften the initial engagement into forward or reverse. That was added in the auxiliary valvebody in sometime 1987.
Old 03-30-2012, 03:15 PM
LsxMatt's Avatar
Car: 86 Sport Coupe
Engine: 5.3 LM7
Axle/Gears: 4th gen 3.42 posi
Mine did the same thing when i had an auto. You can see its really bad in my one wheel peel video:
http://www.youtube.com/watch?v=LOcZM...e_gdata_player
Old 03-30-2012, 08:09 PM
1986TransAm305's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: LB9 305 TPI
Axle/Gears: Stock 3.27
My '86 T/A with a 700R4 does that a little in reverse, and really bad into drive. I've heard it was my idle speed so I used the tech article on the page to turn it down to the right idle RPM, but it still does it. It's bad- makes the engine jump forward and smack the airbox, and it gets worse as the engine/trans get warmer.
Old 03-30-2012, 09:17 PM
rrf321's Avatar
Car: 91 formula
Engine: 5.7 not o.e.
Axle/Gears: 273 2 wheel drive
Was wondering if your back brakes need adjusted up .just a thought
Old 03-30-2012, 09:30 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
mine does the same, it sucks....
Old 03-31-2012, 02:46 AM
Slow87's Avatar
Car: 87 Camaro Lt
Nope, I already adjusted the drums. I rip the e brake when I throw it into gear to stop me from spinning the tires.
Old 03-31-2012, 03:13 AM
Engine: LB9 305 TPI
And mine has discs, so I can cut that out of the possible causes. I'll be changing the trans fluid tomorrow and taking a look inside the pan for anything bad, as well as inspecting a few other things. I suspect my flex plate is close to gone, but I don't know if that has anything to do with a jumpy transmission.
Old 03-31-2012, 09:27 AM
Car: 1988 Iroc-Z
The flexplate shouldn't have anything to do with it... It might be time for a rebuild with 150k on it...
Old 03-31-2012, 07:14 PM
Engine: LB9 305 TPI
I've got about 120k on mine, but if and when my trans goes, I'll probably be replacing it with an '87+ 700R4, so I get the benefit of the accumulator. In the mean time though, I'll continue looking for what could be causing this. I turned down my idle another tiny bit more today (like 100rpm) with no effect either.
hectre13
12-11-2023 08:14 AM
specialized
06-18-2022 09:26 AM
mizz0313
08-12-2015 06:45 AM
dhonda200
08-11-2015 11:50 PM
1992 Trans Am
08-08-2015 08:16 PM
Quick Reply: Car slams into gear
