trans wont shift out of 1st in drive!
Old Jul 24, 2012 | 05:46 PM
Mad_Max_63's Avatar
Car: 1984 Camaro
I just rebuilt my engine in my 84' camaro and put back in! I got it started and when I try to drive it the autotrans wont shift out of 1st gear! I had some problems with getting the vaccum line back where they go because my sons phone we took the pics with broke so we lost all the pics of the before vaccuum lines! Anyway I asked about it in carb sec but havent got a answer! I thought this may be more into the trans section! BTW if you already dont know this, but this is elct controlled trans not vaccuum control modulator! Anyway I really could us some ideas on how to hook this up, Thanks
Old Jul 24, 2012 | 05:48 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: trans wont shift out of 1st in drive!
It's not electrically controlled, either.
Check the TV cable.
Old Jul 24, 2012 | 06:54 PM
Mad_Max_63's Avatar
Car: 1984 Camaro
Check the TV cable.
yes the tv cable hooked up, but dont remeber if its right! So is the TV cable what controlls the shifting?
Old Jul 25, 2012 | 11:09 AM
Mad_Max_63's Avatar
Car: 1984 Camaro
No help????
Old Jul 25, 2012 | 11:52 AM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
Have you checked the govenor
Old Jul 25, 2012 | 07:55 PM
Mad_Max_63's Avatar
Car: 1984 Camaro
I dont mean to sound like a noob but when it comes to tran im lost! Can you tell me where the governor is on this trans and if possible let me know what other things to look for that could cause this? I just got all the info on hooking up my vaccuum lines and it looks like this isnt causing the problem with this car not shifting out of 1st gear! So now I need to narrow it down, the car has been sitting for a couple years! the trans does have rev, but when in drive it wont go into 2nd or 3rd! Thanks for your help and any advice will be helpful BTW its a TH700r-4
Old Jul 26, 2012 | 02:06 AM
antoine's Avatar
The govenor is right in front next to the speedo housing put pop the cap off and pill the gov out and check the gear
Old Jul 26, 2012 | 09:02 AM
Mad_Max_63's Avatar
Car: 1984 Camaro
athanks again im going to check 2day! I also noticed the speed meter on the dash isnt working, it just sits on 0 when drivingand I have doubled checked the the plug!Could this have somthing to do with it not shifting to?
Old Jul 26, 2012 | 09:50 AM
Pro Built Automatics's Avatar
The governor gear is most likely broke or stripped to cause you not to have any other forward gears.
Old Jul 28, 2012 | 04:40 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
this happened to my 1984.new gear fixed it.
jklein337
Sep 19, 2018 06:23 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
maroe624
Apr 16, 2017 08:29 AM
mizz0313
Aug 12, 2015 06:45 AM
dhonda200
Aug 11, 2015 11:50 PM
