Engine and tranny install
Old Oct 16, 2012 | 12:14 PM
patricklav's Avatar
Car: 92 Camaro Z
Engine: LS 5.3 LM7
Transmission: Built TH350 with 3200 stall
Axle/Gears: 4th gen, 4.10
I just rebuilt the engine (SBC 350) and am adding a rebuilt tranny (700R4). I know the ideal installation method is to install them together, however im having a hard time getting someone over to help me with that and i cant stand waiting any longer.
Should i install the tranny or the engine first? Anything for me to be aware of as i install these (its my first installing either).
thanks
Old Oct 16, 2012 | 12:19 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: Engine and tranny install
Installing them together is alright if you have the car high enough and you can adjust your tilt during the installation (they make crank tools to do that).
When I installed my 383 I left the 700-R4 in place and put the 383 in and bolted it up. I made sure to install the starter first before doing it. One less thing to have to roll around and it's easier to check proper gap of the starter out of the car. I also made sure to rotate the torque converter and make sure it was properly seated. Since yours is rebuilt transmission you will also want to make sure the torque converter has been filled with transmission fluid prior to installation.
You will need a flexplate turning tool (preferably) or a crankshaft turning tool. You'll need that to spin the flexplate around so you have access to install the torque converter bolts.
What motor mounts are you using?
Old Oct 16, 2012 | 05:28 PM
Personally I also find it easier to install them separately; trans first, then the engine. MUCH easier than trying to raise all that stuff up high enough to clear, dealing with trans fluid everywhere, etc.
If that's all that's holding you back, go ahead and do it.
Old Oct 16, 2012 | 08:34 PM
patricklav's Avatar
Car: 92 Camaro Z
Engine: LS 5.3 LM7
thank you for the advice. I am using stock clamshell brackets with energy suspension inserts.
Old Oct 16, 2012 | 08:39 PM
patricklav's Avatar
Car: 92 Camaro Z
Engine: LS 5.3 LM7
Tranny first and engine second, sounds like a plan! That makes sense to me; i like to have more experienced people point me in the right direction before i make a mistake.
Thanks Guys for the help; very much appreciated.
Old Oct 28, 2012 | 10:51 PM
patricklav's Avatar
Car: 92 Camaro Z
Engine: LS 5.3 LM7
I hve the tranny installed. Getting ready to donthe engine tomorrow night. What part of the engine should I bolt the engine hoist to? Heads? Exhaust manifold bolt holes?
Old Oct 29, 2012 | 07:13 AM
Depends on what you've got...
Whatever it is, needs to be something that's symmetrical both front-to-rear and side-to-side. Such as, the same accessory bolt hole in each head, the LF and RR intake bolt, etc. The goal being, that the engine should hang level from side to side and a bit lower in the rear (maybe 2 - 3 inches), basically in the position it will go into the car, without a great deal of force required to adjust its position to match how the trans and motor mounts and so on, are oriented during installation.
Or, use a carb plate.
Old Nov 1, 2012 | 01:00 AM
JamesBond's Avatar
Car: 1991 Camaro
Engine: Freshly cammed 350
Hey there I was wondering what torque converter/Flywheel you are running on the 350 700r4 combo?
Old Nov 1, 2012 | 07:55 AM
Engine: 383 SBC
Automatics use flexplates.
Old Nov 1, 2012 | 01:46 PM
patricklav's Avatar
Car: 92 Camaro Z
Engine: LS 5.3 LM7
Stock flex plate ad 2600-2800 stall converter.
Old Nov 1, 2012 | 03:16 PM
patricklav's Avatar
Car: 92 Camaro Z
Engine: LS 5.3 LM7
Got them both installed and mounted. Thanks for your help!
Old Nov 1, 2012 | 06:04 PM
JamesBond's Avatar
Car: 1991 Camaro
Ok thank you, I was planning on mounting the original stall converter to the new 350 flex plate but the holes dont match up.
Your build looks great so far!
camaro11j
Sep 19, 2018 08:49 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
drathaar907
Aug 6, 2015 04:20 PM
