Trans Go Shift Kit
Old Mar 7, 2013 | 11:30 PM
dctrouant1995's Avatar
Car: 1988 pontiac trans am
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Trans Go Shift Kit
Has anybody used this kit? https://www.700r4l60e.com/store/prod...&cat=65&page=1 If so how do you like it? How was the install, need to get a shift kit for my car. I want to upgrade to the corvette servo while I'm at it and this kit has it
Old Mar 7, 2013 | 11:45 PM
Benc1's Avatar
Car: 1989 Iroc convertible
Axle/Gears: 3.08 posi
Re: Trans Go Shift Kit
I'm not sure if it will work for you but I got this for sale cheap
https://www.thirdgen.org/forums/misc...shift-kit.html
What transmission do you have?
Old Mar 7, 2013 | 11:51 PM
Benc1's Avatar
Nevermind answer is in your signature. Not sure if it will work for you, but it may. I was always told the 4l60e was a 700r4 controlled by computer. Not sure though.
Old Mar 8, 2013 | 09:08 AM
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
I'm going to email pro built and see if that kit would work with a 700r4. I'll let you know
Old Mar 8, 2013 | 09:11 AM
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Yea basically a 4l60e is a computer controlled 700r4
Old Mar 8, 2013 | 09:55 AM
lunati397's Avatar
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
I put that kit in my 700 and loved it and I have since installed it in every gm auto ive owned 2005 1500 truck loved it made it drive 1000 time better my 2008 Vmax 1500 made a huge difference really woke the truck up
and I will not do a LSX swap auto without installing this kit Its worth every cent
In my 1500 i had 80 k and towed a 15500 trailer from FL to NM and only issue i had was blowouts I checked the tranny fluid when I got there and it still looked great and I was getting blowouts from going to fast lol (mind you my truck was rated for 8500lbs)
Old Mar 8, 2013 | 10:17 AM
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Nice! Looks like I'll be getting a shift kit eventually
Old Mar 8, 2013 | 10:20 AM
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
4l60e and 700r4 kits don't interchange
Old Mar 8, 2013 | 11:16 AM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
I used the 700-2-3 which is the same kit without the servo and boost valve.(I had already done the servo) It's pretty easy to do. You will need a tiny torque wrench. Also the drill bits that come in the kit will break. I like the kit overall. First to second shift is a little firm at part throttle but not as bad as the crappy B&M kit. It did fix the 2-3 no shift problem I was having at WOT.
Old Mar 8, 2013 | 05:10 PM
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Alright cool, does the corvette servo help any?
Old Mar 8, 2013 | 10:03 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
I have the kit mentioned in the original post. Except that mine is the street/strip version rather than the heavy duty version. I would recommend the street/strip version.....The heavy duty version is more for towing, small pickup trucks. The street/strip version is more for Camaros, Corvettes, etc.
You will love it. Pro Built Automatics make the best Trans-Go kits out there.
Old Mar 8, 2013 | 10:04 PM
The servo fill firm up 1-2 shift. What is your tranny shifting like now?
Old Mar 9, 2013 | 02:59 AM
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
https://www.700r4l60e.com/store/prod...&cat=65&page=1 is this it?
1-2 takes forever to shift, won't shift and go into overdrive at WOT, i can get it up to 5300 rpms tho, I got it up to 5500 once. I only have a 6000 rpm tach haha, so I really want it to shift into OD at WOT
Old Mar 9, 2013 | 03:05 AM
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
If I take off from a stop and floor it, it'll spin forever in 1st, grab traction, then take forever to shift into 2nd. But if I manually shift it, it does great 1st-2nd and 2nd-3rd shifts, But can't get it to go into 3rd-4th at WOT. I need a manual transmission, but that cost way to much money to change over so I'm stuck with an automatic
Old Mar 9, 2013 | 10:47 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
You can install a Corvette servo for around $25.00 and you will be amazed at what a difference it will make.(If your transmission is in good working order) I don't trust mechanics and I did not want to mess with a perfectly good trans. at that level.
I installed the servo and that's it. Off the line both tires will spin for a second then hook. It “barks” the tires going from 1st to 2nd and “chirps” them going from 2nd to third. Thats both tires. I decided with shifts like that I don't need a shift kit. Here's how to change the servo.=
http://www.sethirdgen.org/servo.htm
Old Mar 9, 2013 | 11:16 PM
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Nice! May just order ther servo for now then a shift kit later
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
camaro11j
Sep 19, 2018 08:49 AM
italiano67
Dec 11, 2016 09:21 AM
TreDeClaw
Aug 14, 2015 06:58 PM
dhonda200
Aug 11, 2015 11:50 PM
