T56 clutch questions,again
Old May 14, 2013 | 09:21 PM
johnod's Avatar
Car: A little OT, with Camaro drivetrain
Axle/Gears: 4:11s
I'm planning on changing my slave cylinder as per this thread,
https://www.thirdgen.org/forums/tran...ic-clutch.html
and have a few questions i hope someone can help me with.
1- What is the fluid used?
2- I see the present slave line seems to be held in place with a roll pin, do I just drive that out to remove the slave?
3- Do I just put the line in the new slave and drive the roll pin in?
4- Is there any special bleeding info I need to know?
I haven't got the new slave yet, so don't know if it has a bleeder fitting.
Thanks for any help
j
Old Jun 18, 2013 | 05:44 PM
johnod's Avatar
Axle/Gears: 4:11s
Re: T56 clutch questions,again
Well I didn't get any answers, but went ahead anyway.
The Cavalier slave cylinder fix worked great, solved the problem , better feel at the pedal, and easier to depress pedal.
Just as others said, works great.
Old Jun 20, 2013 | 11:20 AM
fatalicshock's Avatar
Car: 87 Trans Am
i have just done a t56 swap and i was wondering also if there is any special bleeding instructions
Old Jun 20, 2013 | 11:23 AM
johnod's Avatar
Axle/Gears: 4:11s
With the cavalier slave it's easy as it has a bleed screw.
I bench bled the system, very easy.
Old Jun 20, 2013 | 12:01 PM
Car: 87 Trans Am
i took the whole system out of a 97 TA and there isnt a bleed screw
Old Jun 20, 2013 | 12:10 PM
johnod's Avatar
Axle/Gears: 4:11s
That is correct.
If you read my earlier post it states I used a caveleir slave.
If you took a complete closed system out it should be bled already.
Failing that there are some good videos on youtube.
Old Jun 20, 2013 | 12:15 PM
Car: 87 Trans Am
thanks i had to open the system because i broke my master rod so i have to rebleed it sorry i was still on selective hearing/reading mode from being around my better half XD
Old Jul 14, 2014 | 11:08 AM
Keoman's Avatar
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
I know this thread is a bit old but in the interest in saving someone time, I wouldn't bench bleed a system that was already installed in the car, vacuum bleeding works as good if not better and can all be done without removing anything except the reservoir cap.
Had the roll pin come out of my clutch hydraulics and never bled the system afterwards until today, works like new now.
If you have someone else to push the clutch, you dont even need a vacuum gun, you can pull an easy 15 hg/in vacuum using your mouth.
This works for LT1 style T56 clutch hydraulics without a bleeder screw on the slave.
http://performanceworks1.com/ls1_clutch_bleeding.htm
hayesaw0210
Aug 23, 2015 11:15 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
hokis
Aug 9, 2015 03:57 PM
rsrmoore
Aug 7, 2015 08:44 PM
