where to get vss
Car: 92 25th anv camaro rs
Engine: 305 tbi
Axle/Gears: 3.08s non posi
where to get vss
I have a tbi 92 Camaro I swapped a 86 firebird t-5 into and im looking for the vss or something to make my speedo work again.
I came across http://tpiparts.net/inc/sdetail/10956/7587 and am wondering will this work?
if it wont then does any1 have a link, or the part, I need?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Car: check
Engine: check
Transmission: check
Engine: 305 tbi
Re: where to get vss
that's what I thought but since my engine is TBI is should be fine... unless the fbody tbis use a buffer box with the tbi and tpi, in which case im screwed
Car: check
Engine: check
Transmission: check
For your car with the electronic speedometer, it won't work. The '90 - '92 TBI 3rd gens use a 4K PPM magnetic (sine wave) VSS that feeds a 4-OUT BUFFER box. The buffer then feeds digital streams to the speedometer (4K), cruise control (2K), and ECM (2K).
The forth output (4K) is unused.
Note that Firebirds got the magnetic VSS in '89 (maybe '88?).
See jagsthatrun.com. They have the VSS you need. Be sure to download the pdf they have on their VSS page. You may need to order it with the extension cable to clear the tunnel.
You may be able to use the VSS listed way above along with an SGI-5 box. Have that box create a 4K sine/magnetic signal to feed the 4-OUT BUFFER. Be sure to read the documentation for the SGI-5 before ordering, just to be sure it can do this.
RBob.
Engine: 305 tbi
insert bad words here followed by a bunch of !
sigh sometimes I hate our cars.
update: I may not have the wrong part after all. I quote from jagsthatrun.com,
There are 4 types of VSS signals required by the ECM:
1. The two-pulse (2000 pulses per mile) square wave (D.C current or direct current) used on all TBI engines thru 1992, all computer-controlled-carbureted engines, and on 1985-1989 TPI engines.
2. A four-pulse (4000 pulses per mile) sine-wave (A.C. current or alternating current) signal is required by the 1990-1993 TPI, 1992-1993 LT1 engines, and 1990-1993 Camaro 3.1/3.4 V6 engines.
seeing as how I have a stock 92 tbi and its a v8 not the v6 one would assume that's the right part...
Car: check
Engine: check
Transmission: check
That is what is required by the ECM, not the buffer box or speedometer:
RBob.
RBob.
Engine: Lb9
Transmission: M20
I'm sorry man I told you to buy the wrong thing. Tpi parts 2k ppm must be a optical unit not a magnetic pulse like the 4k ppm retrofit witch the 4k unit would work and the buffer could be ditched but it would take the purchase of the Dakota digital sgi-5. If they end up shipping it ill pay for the return and any restocking fee for giving you bad information.
Engine: 305 tbi
its ok we all make mistakes. I kinda would like to add this as a sticky (not this thread, maybe a cleaned up one) but still seems like it should be since t-5 swaps are common enough.
I just hope they work with me and not try to be dicks like some companys lol. wont now for a couple of days.
Engine: Lb9
Transmission: M20
Angel and Ruth are good people I have sold them several parts.
Elephantismo
Feb 13, 2019 12:51 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
they got my email before beening shipped so the right part is on the way
