i got a 9 bolt and a 10 bolt which to use?
Old Jul 11, 2013 | 09:56 PM
82z28 wrencher's Avatar
Car: 84 Trans Am
Axle/Gears: 10 bolt 3.73 factory
OK i got a 9 bolt with sweet LSD (limited slip diffrential) but its got a so so ratio (idk the ratio but id have too guess in the 3.00 range with disk brakes. Then on the other hand my 84 trans am has a 10 bolt with the gt4 option with 3.73 gear which is sweet but... it has a very tipical 3rd gen LSD that sucks and works when it wants that is also rear disk.
The point of this, which would you use? I want both great ratio and a great LSD the cheapest way possible. Thx you
Old Jul 11, 2013 | 10:01 PM
akanitro's Avatar
Car: 1989 GTA, 2004 Z06, 2008 Expedition
Engine: L98, LS3, 5.4L
Transmission: 700R4, MN6, Auto
Axle/Gears: 3.23, 3.42, ?
Re: i got a 9 bolt and a 10 bolt which to use?
The 9 bolt is much stronger than the 10 bolt. How much torque are you putting out?
Old Jul 11, 2013 | 10:30 PM
Car: 84 Trans Am
nothing spectacular just a 350 so in the 200s. The main thing if i want too do donuts or a nice burnouts i can unlike the gay 2 too 1 wheel peel of the 10 bolt. and 500 or soo bucks for a eaton for the 10 bolt 0_0!!!.. id like to avoid considering the gov "bomb" and the aurburn LSD both are junk from what ive read.The car is a 84 with the l69 gt4 g80 codes so (i know id have too look to be sure) could the 10 bolt have the auburn and could that be rebuilt too be decent?
SO Would my best bet too spend 300 bucks for the 3.70 ring gear set for the 9 bolt? and trust the cone setup LSD it has OR??? use the 10 bolt and just suck it up and save too buy the eaton???
The car probly has 235 255 tq id guess 190hp its a truck engine
but in the future id like too build a 300hp 375tq engine for the car
Old Jul 12, 2013 | 07:00 AM
big gear head's Avatar
If the 9 bolt has the 2.77 gear then you would have to change the differnetial to a 3 series before you could do the gear swap. Have you looked at the Yukon Dura Grip for the 10 bolt? It's not as expensive as the Eaton, but still MUCH better than the Auburn. The Auburn can not be rebuilt at all. Check with Tom's Differentials on a price for the Eaton. You might be surprised at how low his prices are.
Old Mar 1, 2014 | 12:10 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Will you ever stop slandering Auburn? They still give twin black stripes after 120,000 miles and none of these folks will ever put that many miles on one.
Old Mar 1, 2014 | 03:31 PM
vortec350s10's Avatar
Car: '88 Iroc
Engine: Single turbo Vortec 5.7, Megasquirt
Transmission: Probuilt 700r4 3000 stall Vigilante
Axle/Gears: Moser 9" 3.25 w/True Trac
I've ran 2 different 9 bolts in my car and the posi's on both were worn out. With the 10 bolt, if you swap it in and the diff is worn out, it is much easier to find/buy a new limited slip carrier for it. I wouldn't worry about strength differences unless you see major hp upgrades and sticky tires in your future.
Old Mar 1, 2014 | 04:36 PM
Nope, I will never stop warning people about how bad the Auburn is. If I saw a snake about to bite you I would warn you about that too. I have personal experience with more than one new Auburn that was completely shot in less than 9 months, and I have scraped the metal sludge out of many rear ends after the Auburn was worn out. They are crap and there are much better differentials out there for just a little more money.
Old Mar 3, 2014 | 11:10 AM
Dgreen87's Avatar
Car: 1987 IROC-Z camaro
Engine: 305 tpi
Axle/Gears: borg-warner 3.27
had a 10 bolt with 3.23 in it worked great till the housing broke swapped out for a 9 bolt and it runs much better eventually after doing donuts and burn outs your going the need a rebuild compare prices for both rears and make your choice that way.
think of it like a new car. you dont buy the Benz that kills you on parts you buy the IROCZ because its better and cheaper. lol
Old Mar 4, 2014 | 02:19 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I'd run the 10-bolt. 9-bolt is cool, but lord help you when you need to repair/rebuild anything in it.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Numbah-1
Sep 12, 2015 08:57 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
