Crack in tq arm bracket/t5
Old Feb 26, 2016 | 05:29 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
Just noticed this today.
Just my luck :/
Old Feb 26, 2016 | 08:14 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: Crack in tq arm bracket/t5
i thought i saw a post where you were going to get some exhaust welding done? maybe find a shop with TIG aluminum capabilities? its not a hard fix for a good welder. better move your mount off the tranns before it happens again obviously.
Old Feb 26, 2016 | 09:50 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
Yea found one that said they could tig weld it. Hoping it holds up ok.
Old Feb 26, 2016 | 09:51 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
yea I've got it at a shop that said they can tig weld it. Of course this had to happen after I spent forever getting the torque arm bolts back in after changing the bushing. Is this a common issue?
Old Feb 27, 2016 | 08:22 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
I'd say its kinda common. think about it,...a lot of your engines power ends up on that mount/bolt/ear, trying to lift up on acceleration, and come down on hard braking. so its constantly trying to push up and down. then it wants to twist side to side when you drive over un-even surfaces. might be a good idea to look into a tunnel mount system or one that moves the mount to the crossmember if you dont want it to happen again.
Old Mar 5, 2016 | 01:45 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
I ended up having it welded but I need to get a Helicoil kit. Would it be easier to swap tail shafts with my spare which is a v6 t5 or should I just go ahead and buy a helicoil kit?
Old Mar 5, 2016 | 02:01 PM
RamIt's Avatar
Car: 1984 z28
Engine: Crate replacement L31R 350
Axle/Gears: 7.625" 28 spline 3.23
If it was my car I would take the opportunity to get the torque arm off the tail housing.
Possibly use something like this?
http://www.bmrsuspension.com/?page=p...411&superpro=0
Old Mar 5, 2016 | 03:00 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
I would heli-coil it since you already have it welded.
Too late, but If the V6 T5 spiral fluid passage in the tailhousing casting and the plastic fluid sprayer cup pressed into the end of the countershaft are the same, you could use the V6 tailhousing.
Old Mar 5, 2016 | 03:49 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
Helicoil it is-turns out the v6 tail shaft is broken off. :/
breathment
Aug 9, 2002 11:51 PM
redraif
May 16, 2002 05:22 PM
ChevyLuva3
Jan 28, 2002 10:52 AM
1991camaroRS
Aug 29, 2001 12:27 PM
One Eyed Jack
Jul 23, 2001 11:00 PM
