Grinding During Engine Braking
Old Feb 15, 2018 | 09:22 AM
Djankus's Avatar
Car: 1984 Trans Am
Engine: 5.0
Transmission: Borg-Warner T5
Hey folks,
My 84 TA is making a grinding sound when I take my foot OFF the gas in gear; noise happens in all gears. As soon as I give it the slightest bit of throttle, it goes away. I also get the same grinding at all times in reverse. Noise seems to be coming from the transmission, am I looking at a worn clutch or stripped gearbox? I suppose it could also be a wheel bearing, but that doesn't explain why it disappears so suddenly.
Thanks for any suggestions!
Old Feb 15, 2018 | 10:31 AM
LsxMatt's Avatar
Car: 86 Sport Coupe
Engine: 5.3 LM7
Axle/Gears: 4th gen 3.42 posi
Re: Grinding During Engine Braking
Originally Posted by Djankus
Hey folks,
Could be a throwout bearing. What about if you press the clutch in while coasting, does it go away?
Old Feb 15, 2018 | 10:48 AM
Djankus's Avatar
Car: 1984 Trans Am
Engine: 5.0
Yep, it goes away when I press the clutch in.
Old Feb 15, 2018 | 10:58 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Narrowing it down.... What does it do in neutral while coasting, and clutch out?
Old Feb 15, 2018 | 11:13 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
It could also be a rear end noise they tend to transmit through the torque arm.
Old Feb 15, 2018 | 11:15 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
That's where I was heading...pinion bearing
Old Feb 15, 2018 | 03:53 PM
Djankus's Avatar
Car: 1984 Trans Am
Engine: 5.0
Just drove around for a bit. I get grinding while coasting in neutral with the clutch OUT. Once again, noise goes away when the clutch is IN. Throw-out bearing?
Old Feb 15, 2018 | 04:30 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Throwout bearing
Old Feb 15, 2018 | 04:57 PM
Djankus's Avatar
Car: 1984 Trans Am
Engine: 5.0
Throwout bearing
Thanks everyone for the help, I'm floored by how fast you all responded!
Old Feb 15, 2018 | 05:34 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
It's a good knowledgable group.
Old Feb 19, 2018 | 07:04 AM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Hold on, guys.
Throwout bearing typically makes the noise with clutch pushed in.
I'm going with Bob's original statement: pinion bearing.
Symptons are classic.
Old Feb 19, 2018 | 08:07 AM
Djankus's Avatar
Car: 1984 Trans Am
Engine: 5.0
Originally Posted by 86LG4Bird
Hold on, guys.
Thanks for the reply. I'll probably have to replace all the bearings, the car was neglected for a time and they're all in questionable shape, but cheap. What I was really worried about was stripped gears, which it sounds like it isn't.
Old Feb 20, 2018 | 08:24 AM
paulmoore's Avatar
Car: 1988 Camaro(92 Z28 clone)
Engine: Forged 383, AFR 195 419/430@wheels
Transmission: Monster 700R4 Yank 3600 stall
Axle/Gears: 9in Detroit locker-3.90's,35 spline
A friend of mine had an issue once where the thrust bearing of the crankshaft was worn out. This allowed the crankshaft to move forward and backwards in the main journal area.
​ You can observe this by watching the crank pulley or harmonic balancer while someone revs up the car or engages/disengages the clutch. If the crank moves too far forward, then the flywheel could be rubbing up against the back of the block.
Old Feb 21, 2018 | 07:50 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Sounds like the rear gearset, on the coast side since it goes away when he gives it any throttle, my car does the same thing
Old Feb 21, 2018 | 07:53 AM
midias's Avatar
When i busted a tooth off my pinion gear I had 3 people swear the sound was coming from the trans area. That tq arm is tricky
Old Apr 3, 2018 | 03:24 PM
Djankus's Avatar
Car: 1984 Trans Am
Engine: 5.0
UPDATE for you guys:
Pinion bearing was the winner! Bought a rebuild kit, had a shop replace all bearings in the diff, grinding sound is gone. Interestingly, they said that there was no preload on the pinion when they opened it up, so that bearing was set up to destroy everything. Glad I didn't have to learn that one the hard way. Thanks again everyone for your help in diagnosing the issue!
Old Apr 3, 2018 | 05:36 PM
There never is, if it has more than 20k miles or so on it.
I kinda wish there was a way to reset it periodically, like we do with front wheel bearings. The comparison is actually fairly comparable. Problem is, especially with a crush sleeve, it's REAL hard to measure pinion bearing preload properly, let alone SET it, whereas it's pretty easy w front wheel brgs; but in reality, only a VERY TINY amount of bearing wear, affects it DRAMATICALLY. Again, just like front wheel brgs.
Once it goes away, the bearings start failing MUCH faster, since they are no longer held in proper contact. The small "tail" bearing, the one behind the yoke, usually shows it up first; but sometimes the larger "head" bearing does. Most rear ends that whine under ONLY either acceleration or coast need bearings, not gears.
If there was a way to restore it occasionally, there'd be AHELLUVALOT less wasted rear axles in the world. Unfortunately I have no solution I can offer. I can only state the problem clearly, but not the solution.
had a shop replace
What's this? "Shop" is something women do for handbags and shoes; are you saying some of those will actually mess with your rear end? (well, your car's, that is)
Old Apr 4, 2018 | 07:38 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Wouldn't a solid pinion spacer solve the problem? Since you put it in with shims, you can just remove shim to tighten it back up.
Old Apr 4, 2018 | 07:45 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I us solid pinion spacers in all my rearend rebuilds.
Old Apr 4, 2018 | 08:15 AM
I use those too; but the bearings still wear, and the preload goes away as a result. But since I can tighten the nut MUCH tighter that way than with a crush sleeve, at least it doesn't back off.
TheScaryOne
Brakes
Jun 28, 2010 02:36 PM
BADCAM70
Aug 20, 2006 11:04 PM
TRSCobra
May 3, 2006 12:33 PM
83TransAm
Jun 9, 2002 07:05 PM
86TpiTransAm
Apr 16, 2002 09:04 PM
