What is the best transmission to use with a 350 small block in a 1984 trans am not to
Old Mar 27, 2018 | 06:44 PM
hooliewoodyella's Avatar
1984 firebird trans am
Old Mar 27, 2018 | 06:49 PM
Re: What is the best transmission to use with a 350 small block in a 1984 trans am no
Auto or manual?
Old Mar 27, 2018 | 06:55 PM
auto just for daily driving
Old Mar 27, 2018 | 06:56 PM
The one it came with (700-R4), suitably reinforced if your particular 350 needs it.
Old Mar 27, 2018 | 07:07 PM
Even if the car doesn't have the original engine in it ???
Old Mar 27, 2018 | 08:30 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
I also think a th700 would be a good choice-pretty much a bolt in into an '84.A th350 would also be ok-especially if your axle ratio is 3.23 or steeper.TH350 not a direct bolt in,but still easy to install.
Old Mar 27, 2018 | 09:02 PM
thanks
Old Mar 28, 2018 | 07:49 AM
Assuming your 350 is a Chevy small block, then your existing transmission bolts RIGHT UP to it, since the 305 it originally came with is also a Chevy small block.
3rdgenparts
Mar 24, 2019 04:33 PM
sugarsn10
Jul 26, 2018 09:28 PM
Armada95
Apr 26, 2018 05:29 PM
TADailyDriver
Apr 14, 2018 08:07 AM
