Help determining rear end gears
Old Jul 2, 2019 | 10:26 PM
LikeARock47's Avatar
Guys, this is really confusing me. I have a 92 Z28 5.0 TPI automatic. The RPO label has codes GU2 and G80.
According to the GM master RPO list, GU2 = 2.73 gears and G80 = limited slip. I can confirm it is limited slip as it spins both wheels.
Cruising on the highway at 75 mph, I'm at 2300 RPM in OD. However, all of the "gear ratio to speed" calculators online, such as this ( http://www.tremec.com/calculadora.php ) all give me the same result that is way off, saying 90 MPH:
Tires are 25", and I know 4th gear on the 700R4 is 0.7 ratio. BUT, if I change the axle ratio in that calculator to 3.23, it comes out just about right:
I got this car with VERY low miles, and in bone stock condition, so I highly doubt the rear end gears have been changed, but I don't know what else it could be. I verified the speedometer against a GPS and it's dead on.
Although I have a lot of experience working on cars, I'm new to thirdgens, and performance upgrades in general. So can one of you experts explain this to me?
Old Jul 2, 2019 | 10:46 PM
88IROCvertZ's Avatar
Car: 1988 IROC Z Convertible
Engine: 305 TPI (LB9)
Transmission: 700 R4
Axle/Gears: G80 GU2
Re: Help determining rear end gears
A lot of people liked to swap gears in these cars even with low miles.. I remember a buddy of mine did his back in the day with 20k miles and I believe if you change the speedo gear your speedometer will read correctly..
I’ll have to plug mine into one of those calculators and see what comes up..
Old Jul 2, 2019 | 10:47 PM
Axle/Gears: G80 GU2
I like this calculator too, but it comes up similar to what you got with the other one..
https://www.chevellestuff.net/tools/rpm_calculator.htm
Its already setup for the 700r4
Old Jul 2, 2019 | 11:38 PM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
iirc, u can spin you back tires and count turns to confirm gear ratio
Old Jul 3, 2019 | 12:34 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Lift the tires off the ground, put a piece of tape on the drive shaft and one of the wheels, put the trans in neutral, and spin the tire while counting the revolutions of the drive shaft. The more times you spin the tire around the more accurate your findings will be.
If both tires spin the same direction, then axle gear ratio is the drive shaft revolutions diveded by tire revolutions. If wheels spin in opposite directions, the calculation is slightly different.
Old Jul 3, 2019 | 12:57 AM
Drew's Avatar
Forget all the codes and counting turns, blah blah blah. Pull the cover off the back, turn the ring gear until you see a stamp with two numbers with a : between then. Divide the larger number by the smaller, and that's your gear ratio. Every other method you're guesstimating. Reading the manufacturer's stamping tells you the actual gear ratio.
Old Jul 3, 2019 | 01:01 AM
Fascinating. I'm gonna try that this weekend, thanks!
I'm also questioning the accuracy of the tach now, after reading on this forum that these cars have a common issue with the tach reading too high, which is fixed by replacing the tachometer circuit board. Is there a way to test that? I have a Tech 1A scanner which should read the RPMs, but would that reading also be thrown off by a bad tach circuit board?
Old Jul 3, 2019 | 11:46 AM
GeneralDisorder's Avatar
There's a really good solution to this - buy and install a 3.73 gear set - the're cheap. Whatever is in there will be lower than this so you'll get a performance boost no matter what. And if it still has the 2.73.... well then it needed swapped out didn't it?
Tach reading will not affect the ECM. ECM determines RPM from the distributor/coil. It could care less if the car even has a tach.
GD
Old Jul 3, 2019 | 01:32 PM
GD
Got it. I'm gonna physically check it tomorrow and find out what's in there. If it has a 3.23 I will probably keep that. This is not a daily around town car, I mostly do long highway cruises with it. And yeah, 2.73 is crazy for these cars.
Old Jul 4, 2019 | 07:37 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Who knows when the rear fluid was changed. If ever. Verifying gears would be a good time to do that:
What Gear Ratio Do I Have?
Jerk the diff cover. The numbers are stamped on the ring and pinion.
41 : 15 = 2.73 (RPO GU2)
41 : 14 = 2.93 (RPO GU3)
40 : 13 = 3.08 (RPO GU4)
42 : 13 = 3.23 (RPO GU5) / Approx. RPM’s at 70 mph--2133
41 : 12 = 3.42 (RPO GU6) / Approx. RPM’s at 70 mph--2255
41 : 11 = 3.73 (RPO GT4) / Approx. RPM’s at 70 mph--2463 (Note that 3.73's were only available 1983-86)
JamesC
Old Jul 4, 2019 | 04:41 PM
If both tires spin the same direction, then axle gear ratio is the drive shaft revolutions divided by tire revolutions. If wheels spin in opposite directions, the calculation is slightly different.
Ok so I just did this, and for each 1 revolution of the wheels, the driveshaft goes around 2 and 3/4 times approximately. So that would mean 2.73 gears right? That matches up with the RPO label, but then why do all those calculators say different?
I did change the rear axle fluid a few months ago, but didn't think to look for markings on the gears then.
Old Jul 4, 2019 | 06:59 PM
Denn11's Avatar
Car: 1988 Camaro IROC-Z
Engine: LB9 305
Axle/Gears: 9 Bolt 3.45
So you know your tire diameter - 25" (Was this height calculated, measured, etc, probably close enough anyway)
You know your speedometer is accurate( (verified against your GPS)
Pull the diff cover and verify the tooth count against the gear markings (people make mistakes)
Assuming all is well in your transmission....
That should just leave your tachometer as the unknown
Old Jul 31, 2019 | 05:14 PM
Turns out the tach is wrong. I connected my Tech 1a scan tool to the car and checked the RPM on there, and the tach is reading quite a bit higher. Apparently it is a common problem where a small circuit board on the tach gauge goes bad and does that, there are several long threads about it. Just ordered a new tach circuit board from Cajun Tach Shop.
Old Jul 31, 2019 | 06:14 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Not to hijack this thread, but my rearend came out of a '84 Z-28 with the L-69 H.O. and 700R-4. From everything I read, it should have been a 3.42 ratio, which I thought would be ideal, but spinning the wheels and counting the driveshaft revolutions just wasn't coming out right, so I pulled the cover and counted the teeth on the ring & pinion. 'Turned out they are 3.73s. Apparently, this was the "G92" option. I thought 3.73s could be had only with a manual transmission. Anyway, counting the teeth removed all doubt, and the gear oil needed to be changed anyway.
On another note; I don't think those online calculators are 100% accurate, but probably somewhat close...
91R5
Sep 3, 2009 06:55 PM
t_ritt06
Mar 7, 2009 01:23 AM
3rdGenSkan
May 29, 2008 03:54 PM
HenryC
May 31, 2002 06:23 AM
Abe91Z28
Dec 30, 2000 11:57 PM
