Quick!!! Need help on shift kit Install
Old Jan 17, 2002 | 04:10 PM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
im installing a transgo shift kit, and i pushed the boost valve up into the tranny like it said too. it is above the slot for the snap ring but it doesn't move. it wont go in or come back out. i dont think this should be like this because in the video they could push it up and the spring would bring it down. how can i get it out.
Old Jan 17, 2002 | 05:19 PM
transfixleo's Avatar
How far up is it? If it is only slightly then put the snap ring in place and new try tapping onto the bottom of the TV Boost Valve and see if it comes back down. You can also try starting the car once it is together as pressure will push it back down. Try to get it back the other way though since it could damage the groove/ring in the process.
Old Jan 18, 2002 | 12:49 AM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
yeah, everything for the valve is stuck. the bushing is above the seat for the snap ring. it just wont move up or down. so im goin to put everything back together and start the car. pro-built said to put it in reverse and the valve will pop out. will i have to rev it or anything. how long should i keep it in reverse. is too long gonna hurt it. do i have to take the valve body back off to put the boost valve back.
Old Jan 18, 2002 | 04:02 AM
Well do you feel lucky? If you leave the snap ring off it will come out (you will know by the little dent in the pan!), if you leave it in though you run the risk of damaging the bore. I would say leave the clip off, start it (no you shouldn't have to really rev it) and then when you drop the pan again, take a pocket knife and scrape around the snap ring groove. Often a bur develops there and that is what ends up causing problems.
Old Jan 18, 2002 | 10:50 AM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
ok thanks. but will i be able to fix it with out taking the valve body off
Old Jan 18, 2002 | 10:53 AM
Pro Built Automatics's Avatar
Yes.
Old Jan 18, 2002 | 11:04 AM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
ok thanks. you guys have been helpful. and i liked the way pro-built easily told me the answer to my problem when i called him.
Old Jan 18, 2002 | 11:55 AM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
i got another question. my tranny had check ***** in it. they are all the same except for one, which is bigger and is gold. does this one have to go anywhere special or do i just follow the directions and put any checkball in.
Old Jan 18, 2002 | 09:06 PM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
the valve is still stuck. i tried starting the engine but i have no gears. none of them will engage. i dont know whats wrong with it. i did everything that was in the video and instructions. how else could i get this valve down. i really need my baby running again.
Old Jan 19, 2002 | 09:15 AM
Don't take this wrong but I know when things start going bad it can get confusing. Did you fill the unit up again?
Old Jan 19, 2002 | 12:39 PM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
yeah i filled it back up with tranny fluid. should i just start the car and leave it in reverse. will it eventually engage in gear and blow it out. or can i rev it in reverse. i still have no gears. im getting so pissed, i was thinking of gluing a stick to the bottom of the boost bushing and just pulling!!!!!!
Old Jan 19, 2002 | 01:17 PM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
i got a problem. the valve isnt in there. i found it in my drain pan. so everything else is in there. thats y it wont blow out. now what do i do.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
camaro11j
Sep 19, 2018 08:49 AM
TreDeClaw
Aug 14, 2015 06:58 PM
dhonda200
Aug 11, 2015 11:50 PM
drathaar907
Aug 6, 2015 04:20 PM
