Prepped 10-bolt vs 9-bolt
Car: 86 Camaro Z28
Engine: LT1 200cc Ai heads and cam
Axle/Gears: 4.10:1 Zexel Torsen
Please don't start off with, "Just put a 9" in it". This is for me to determine if it's worth it to switch over to a 9-bolt, or is the difference negligible. Currently, I have about 450HP to the wheels. My goal is to do recreational auto-x and possible road course driving and not really drag racing. My concerns are weight, power drain, factory torque arm attachment, and budget.
Current Setup:
Current Setup:
- 2002 Z28 axle
- Zexel-Torsen differential
- 4.10:1 ratio
- Welded axle tubes
- Cover girdle
- Solid pinion spacer <- forgot to add this
- Similarly setup, will it be stronger?
- I would be adding a helical gear differential, instead of the original cone setup
- What is the difference in weight?
Engine: 4++,350 & 305 CIs
Re: Prepped 10-bolt vs 9-bolt
The problem you'll have in a 10bolt with 373/410 and deeper gears is that the pinion gets small and doesn't share the load with as many teeth. They tend to break teeth and pinion heads off.
iirc, they are close enough to the same weight not to worry about that. id use the 9bolt with upgraded diff because of the bolt in axles, no c-clips like the 10bolt.
vorteciroc (02-03-2024)
Current Setup:
Current Setup:
- 2002 Z28 axle
- 4.10:1 ratio
- Welded axle tubes
- Cover girdle
Car: 86 Camaro Z28
There are helical gears available, but all the companies I found so far are in Australia. The search I used was for M78. Mace Engineering diffs can be find in eBay. There are at least 2 more manufacturers I've found, but I'm out of town for the weekend. I can post up the links I find when I get home. I haven't emailed anyone to figure out model fitment, yet.
Mace M78 search
Mace M78 search
rhyno91 (02-03-2024)
Car: 86 Camaro Z28
Will the slightly larger gear in the 9-bolt help with the pinion issue? That also sounds like a problem with the case flexing a little bit.
Mace M78 search
Mace M78 search
Good luck with your build, no matter what you end up going with.
I could be off here but I don't see any real difference in /strength between either of them. The standard 10 bolt with the 8.5 ring vs the 9 bolt 7.75" in a better housing. A solid built 10 bolt is not weak garbage.
Car: '92 RS
Engine: 5.0TBI
Transmission: TKX
Well for one thing, the 10 bolt that comes with third gen's has the 7.5 inch ring gear and that rear is weaker than the 8.5's.
Car: 86 Camaro Z28
I probably should have clarified the 10-bolt is the 7.5".
as others have said, the 10bolt in 3rdgens is 7.5 or 7.625. The 8.5 was a 2nd gen thing and much stronger than the 3rds
STREETDEMON
11-13-2015 02:22 PM
