Which fluid for ‘87 WC T5?
Old Oct 21, 2024 | 03:54 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
I was set to refill with ATF, until I saw this warning “5W30 oil. ONLY!” Seems to be some controversy here with people I talk to. Some say go ahead and use Dex ATF others say use 5W30 oil only. I also believe the factory fill was non synthetic. What should I refill with?
Old Oct 21, 2024 | 07:16 PM
Re: Which fluid for ‘87 WC T5?
Is this really the .... w .... ww.... wo.... worl .... [ppppppppuuuuuuuuuuuuuuuuuuuukkkkkkkkkkkkkkkkkkkkkke] sorry, I just can't bring myself to utter that PIT Team, Total Quality, Six Sigma, 80s BUZZZZWORD without enduring SEVERE digestive upset ... aka 2nd design T-5? Look at the front countergear bearing, post a pic of it if you don't know how to tell.
Old Oct 21, 2024 | 07:32 PM
chazman's Avatar
Axle/Gears: BW 3.45
You know, now that you mention it, I assumed it was a WC, but it's possible it's non-WC in '87.
Old Oct 21, 2024 | 07:45 PM
chazman's Avatar
Axle/Gears: BW 3.45
I'm thinking non-WC but here's a video which shows the front around 36 seconds.
Old Oct 21, 2024 | 08:59 PM
Airwolfe's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
When you posted this instantly my mind said World Class, they had that in 87? I thought 88 was the first year. I didn't look into it any further then just that popping into my head though.
As to what lube it says 5w-30 right on it so I guess that is probably what you should put in it.
Old Oct 21, 2024 | 09:48 PM
chazman's Avatar
Axle/Gears: BW 3.45
That's where I'm leaning. I wonder if 5W30 synthetic is ok? IIRC, the non-WC had some sort of an issue with synchros needing more friction, which is why they had gear lube. I can't imagine the factory fill not being conventional oil.
Also, I should probably change the title.
Old Oct 21, 2024 | 09:55 PM
The non- w ... w ... wo ... [ppppppppppuuuuuuuuuuuuuuuuuukkkkkkkkkkkkkkkkkkke] ... yeah, the 1st design T-5, had brass blocker rings, same as any/all 3- & 4-speeds since the dawn of synchronzied transmissions. Therefore need the same lube.
Looks like in 87 the CAFE team won the closed-door cigar-smoke-filled conference room debate which was moderated by the "Finance" group. Since THE PARTS are the same as all those other transmissions for all those years, I'd use the same lube, as all of them did for ... what, half a century?
Which would be, gear lube. My go-to for the 1st design T-5 is (was) Mobil1 75W-90. Glad I don't have to deal with those POSs in my car anymore.
Assuming of course, that yours is the 1st design. I have of course no way of knowing that; it's too dark out now for me to see your transmission through my monitor.
Old Oct 21, 2024 | 10:31 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Since the fluid currently in it is probably the factory fluid, you could drain it to see what comes out, and then decide what you want to put into it. I suspect ATF will come out. That's what was in mine, even though mine also has a 5W-30 tag on it.
Old Oct 21, 2024 | 10:40 PM
Airwolfe's Avatar
The sticky at the top for T5s has pics to show you which T5 you have NWC/WC. In there people go back and forth as to what type of lube to use in it.
Old Oct 21, 2024 | 11:12 PM
ANY lube (almost) is better than NO lube.
At some level it's hair-splitting to worry about which one is "original" or "right" or "best". Especially with a 1st design T-5; they leeeeeek SO MUCH out from around the front countergear bearing, the best thing to do, is KEEP EM FULL. With whatever you've got or can get quickly.
Old Oct 21, 2024 | 11:14 PM
chazman's Avatar
Axle/Gears: BW 3.45
Screen shot from the above video. Looks a lot like a WC,
Old Oct 21, 2024 | 11:23 PM
chazman's Avatar
Axle/Gears: BW 3.45
No kidding. Interesting.
Old Oct 21, 2024 | 11:34 PM
Yeah, looks more like the 2nd design. So, not original to the car. Not that that particular detail matters all that much, beyond just IDing it.
2nd design T-5 has composition material on the blocker rings; same basic stuff as automatic transmission clutches. It also has tapered roller bearings with preload, rather than straight rollers with thrust washers and end play.
Use ATF. Best fluid for the blocker rings which are auto trans clutches in miniature. Of course, putting what the cap says in it, while maybe not in accordance with the TRANSMISSION MANUFACTURER'S recommendations (B-W's, not GM's), is probably OK enough; better than letting it run dry, if maybe not ideal.
Old Oct 22, 2024 | 01:37 AM
Airwolfe's Avatar
You got better vision than I do.
Old Oct 22, 2024 | 01:41 AM
LAFireboyd's Avatar
Now you'll get an "interesting" from me, Chaz. Throughout all these years, it's never occurred to me to compare mine, so I just crawled under to take a look, and it's also like the WC in the bottom picture. And mine IS original to the car, 100% guaranteed.
With 1987 being the first model year the T5 was bolted up to the ~300 torque TPI engine, it would've made sense for GM to use the new "stronger" WC instead of the old "weaker" NWC. Or maybe the WC was used on V8s only, or it was a mid-late model year changeover leading into the full release for 1988. OR maybe the NWC doesn't look like the one in the top picture.
Edit: I was typing while Airwolfe was posting his pictures, and it appears that his picture of the NWC is probably the accurate one, and our NWC cases look the same across the bottom as the WC, so we can't go by that.
Old Oct 22, 2024 | 08:49 AM
chazman's Avatar
Axle/Gears: BW 3.45
The plot thickens.
Old Oct 22, 2024 | 12:00 PM
chazman's Avatar
Axle/Gears: BW 3.45
What was the manufacture date on your car?
Old Oct 22, 2024 | 12:03 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
There's a vin number on the engine and transmissions. Not hard to check if original.
Old Oct 22, 2024 | 01:38 PM
If B-W ran out of the 1st design near the end of 88 MY production, then since they were already supplying the 2nd design to Frod & Xler, AND already had all the case dimensions and various other data for GM transmissions (and probably had the drawings and tooling ready to go), AND had a contract for the 2nd design for 89 MY production, it would have made sense for them to talk GM into taking the first run of the 2nd design a little early, rather than drag out the old tooling one last time. Especially since the 2 designs are absolutely interchangeable in the installation. I don't know that it happened here, butt that's the sort of thing that happens at the MY changeover. Either the last few leftovers get consumed à la the few 90 cars w 9-bolt rears, or they dip into the new ones if they run out.
And BTW you can see in my pics that somebody posted up there, that the 1st design has the bell housing flange only just barely surrounding the CG bearing and then leaves a gap between the BH and the bottom front of the rest of the case, whereas the 2nd design has the whole front of the case in that plane, with the triangular cutouts. The screen grab matches the 2nd design case butt is quite different from the 1st design.
Old Oct 22, 2024 | 01:55 PM
LAFireboyd's Avatar
December 1986 on the door jamb label. Invoice shows several dates, from the 19th through the 25th.
Old Oct 25, 2024 | 11:02 PM
chazman's Avatar
Axle/Gears: BW 3.45
So getting back to this. Verifies that ATF is fine in this trans.
Old Oct 26, 2024 | 10:44 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Any third gen T5 is okay to receive ATF as the fluid fill. Including yours. If I had to fill one right now quickly, I would grab regular parts store "Dexron / Mercon" (Dexron III) and use it. Don't use Dexron VI.
Old Oct 26, 2024 | 12:50 PM
chazman's Avatar
Axle/Gears: BW 3.45
Why not Dex VI?
Old Oct 26, 2024 | 01:06 PM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Why not Dex VI?
Post #6 in this thread:
https://www.thirdgen.org/forums/tran...l-1994-gm.html
Old Oct 26, 2024 | 02:08 PM
chazman's Avatar
Axle/Gears: BW 3.45
Originally Posted by Aaron R.
Awesome! Thanks!
Old Dec 1, 2024 | 08:59 PM
JohnFB's Avatar
Car: 1987 IROC-Z
Engine: 5.0L TPI LB9
Transmission: 5-speed manual (T5)
Axle/Gears: 3.45 POSI
chazman,
Did you figure out definitely whether you have a WC or NWC T5?
I went through this a few years ago. Fortunately, I was able to read the
ID tag (after cleaning it up a bit), and I read the number: 1352-185
According to this web page:
http://www.britishv8.org/Articles/Bo...T5-ID-Tags.htm
that number corresponds to "GM 1987 F-Car V8" and it is a non-WC.
That made sense since my car is a 1987 Camaro, and the Camaros
didn't receive the WC version until 1988.
I only came across this message thread today. I find it very interesting that your tag
with "5w30" also had the GM part number (1052931). If you do some research on that
number, you will find it is not just 5w30 motor oil. It was a Texaco (Havoline) conventional
5w30 oil with an additive package modified for good synchro performance.
My 1987 Camaro GM Shop Manual cites this number (1052931), and GM refers to it as "Manual Transaxle Fluid".
This fluid was a forerunner of GM Synchromesh fluid (which eventually superseded it).
You might find this discussion earlier this year interesting, if you haven't seen it before:
Nwc t5 fluid - Third Generation F-Body Message Boards
Old Jul 9, 2025 | 10:41 PM
chazman's Avatar
Axle/Gears: BW 3.45
Originally Posted by JohnFB
chazman,
Sorry for the late reply, I just came across this thread again. Thanks for the link and info!
DirtyCanadian
Jun 8, 2008 10:45 PM
camaro_V6_Tuner
Mar 9, 2004 05:44 AM
Eightyninef
Jul 27, 2002 06:03 AM
Blackened
May 1, 2002 11:53 AM
ev305tpi
Mar 20, 2001 05:30 PM
