car keeps dieing!!!!!!!
Old Apr 24, 2002 | 11:03 AM
90_RS's Avatar
Please help my car keeps dying, it'll run ok for a while ,but then sometimes it'll just want to die, for onr thing it idles really low and I have to put it in nuetral and keep revving the engine to keep it running!Its an auto so you know how much of a pain that is. my mechanic can't find anything wrong with it so tonihgt i am taking it to the chevy dealer.
Old Apr 24, 2002 | 11:23 AM
Drew's Avatar
Sounds like the same problem a couple of us are having... Do the RPM's just drop when you come to a stop and then it dies? or does it mostly just stumble? In my case I'm guessing its either the Torque converter clutch malfunctioning or the IAC malfunctioning...
Old Apr 24, 2002 | 12:07 PM
coolrimsatleast's Avatar
Car: 89 f-bird and some others
Engine: 3.4
Does it run bad while you're cruising along or just when coming to a stop, already stopped, or accelerating?
Old Apr 24, 2002 | 07:48 PM
86RedZ28's Avatar
I used to have an V-6 Camaro that had that problem. For mine the injectors were getting dirty...clean 'em out or try a bottle of fuel injector cleaner. It will only cost you a couple of bucks and it took care of the problem for me.
Old Apr 24, 2002 | 11:36 PM
jump6pack's Avatar
I have the same prob with my 89. I have done the plugs, cap, rotor, wires and am looking next to the egr and O2 sensor. mine will run okay cold, but as it warms up it needs throttle at the stop to stay running. Any help is greatly appreciated.
Old Apr 25, 2002 | 12:18 AM
elevario's Avatar
Car: 1992 RS
Engine: 3.1L V6
Mine has the same problem and it has been bugging the crap out of me! But I found out though if at first my car is running bad then I turn it off and turn it back on and bye bye bad idle!
Old Apr 25, 2002 | 02:11 AM
86bird_28v6_5spd_ramair
Guest
Posts: n/a
"Mine has the same problem and it has been bugging the crap out of me! But I found out though if at first my car is running bad then I turn it off and turn it back on and bye bye bad idle! "
HEY mine would do that too, run like **** but turn it off then back on and all better but now it dont work anymore, idle is now fine but she stumbles in 2-3000rpm range.
Old Apr 28, 2002 | 12:13 PM
Horst's Avatar
Car: Firebird
Engine: 3.1 L
Transmission: auto
ECM ! any bet?
Old Apr 28, 2002 | 12:42 PM
dsaint1347's Avatar
I had the same problem once when I stupidly decided to let a mechanic do my timing and oil change ( I was feeling lazy and did not have a timing gun) Big mistake as far as timing goes, the guyI guess did not disconnect the est cable and did the timing by ear. When I drove off I died as soon as I hit the first light, I figured maybe it needs a little getting used to. Nope same thing I went to sears brought a timing gun looked at what the timing was set a found it was set a 30* yikes I lowered it to 10 and now it works like a charm.
Old Apr 29, 2002 | 07:09 PM
pimpinthaz28's Avatar
The tim\ing is what I was gonna suggest. If its a little off your idle is gonna be too high or too low causing the engine to die.
Old Apr 30, 2002 | 09:45 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yeah guys, buy timing guns!!
Hey; maybe we should forget the group purchase on nitrous/suspension, and go for a group purchase on timing guns!
Old Apr 30, 2002 | 11:47 AM
Camar_Hunter_c's Avatar
I got a decent timing gun for 10-20 bucks. stumbling prob can be traced to vacuum leak, timing, ignition system, EGR system.
Old May 1, 2002 | 12:11 AM
85maro's Avatar
"mine will run okay cold, but as it warms up it needs throttle at the stop to stay running. Any help is greatly appreciated. "
mine is just the opposite, any help
Old May 1, 2002 | 10:36 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
85maro, 9 times out of 10, all these problems are tuneup related, so check out the message that loomdog reposted for me. Also, check for exhaust leaks.
Old May 1, 2002 | 06:35 PM
85maro's Avatar
that is what i thought but i wasnt sure, thanks for the help Tom.
Old May 8, 2002 | 06:21 PM
Ratchet's Avatar
IMHO
If the stumbling occurs at idle or when you decelerate to a stop there are two common causes.
1. Believe it or not the gas cap is not on properly (try this first it doesn't cost anything.)
2. the throtle body is badly coked. (remove boot off of front of TBody and spray with throtle body cleaner. reach in with a rag on a stick or something and clean everything you can then run the engine and spray the rest of the can down the throtle body.)
If the stubling occurs at 2000 to 3000 rpm under load I would check the spark plugs first for fowling.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
killer777
Aug 8, 2015 02:47 PM
